Adapter for flat face hydraulic connector
   / Adapter for flat face hydraulic connector #1
BeezFun
IL
Kubota B2710
The hoses on my brush cutter would like to connect to the machine at a 90 degree angle to the way the 1/2" flat face connectors are currently mounted:
Do they make an elbow that has a flat face quick connect on each side that I could connect to the machine and then to the brush cutter hose? I see all kinds of elbows that have one side NPT and the other flat face, but I don't see any with a flat face on both ends of the elbow. Or should I just bite the bullet and change the fitting on the machine. There are attachments that are happier with the vertically oriented fittings, but I don't have any of them. Both of my attachments would be happier connecting horizontally.
   / Adapter for flat face hydraulic connector #2
Build your own adapters.
   / Adapter for flat face hydraulic connector #3
Get the angle you want then get the couplers you need. Probably cheaper than buying already made ones if they exist. I made the ones I have
Thanks, that helps to see a picture of what you did.
2012 PROCO 130BBL VAC TRAILER (A58214)
2012 PROCO 130BBL...
LOT: (2) Piece Mac Tools TRCH Portable 1000 Tool Box w/Contents: Lower Tool Box: 18-Drawers, Upper (A59076)
LOT: (2) Piece Mac...
12 X 20 CAR PORT (A58214)
12 X 20 CAR PORT...
2015 GMC 3500 HD 4x4 Crew Cab Pickup Truck (A55973)
2015 GMC 3500 HD...
1709 (A58375)
1709 (A58375)
GEARMATIC WINCH (A58216)
GEARMATIC WINCH...
