Add A hydraulic top link.
   / Add A hydraulic top link. #1
Davey Wayne
Fick Mo.
Kubota 2350
I have a Kubota BX 2350 with no front loader and want to install a hydraulic top link and one valve .I want to come off the ports where the loader valve would connect but am kinda confused how I would do that. I can make my own hydraulic hoses and want to do this as inexpensive as possible. Any suggestions would be greatly appreciated. THANKS
   / Add A hydraulic top link. #2
Look into the threads for "top n Tilt" There are bunch of threads on here for it. Let us know how it turns out. We always want pics - Tractor ****...:)
   / Add A hydraulic top link. #3
These are not my pictures, they are from TBN I just don't know who posted them. I don't think they wll mind if I pass them on to you. One is a BXxx and the other is of a BXxxxx. Hope they help.
   / Add A hydraulic top link. #4
Just determine which plug is the pressure line and run that to the rear remotes.
Pb from the remotes will return to the hyd blk.
The OUT/tank line will tee into a tank line.
The remote relief will become the main relief, so adjust 3pt relief and the remote relief to tractor specs.
   / Add A hydraulic top link. #5
You well need that plate where the hoses are hooked to. You well have to look in the loader parts manual to get the part #. See you can hook up where the backhoe hooks, might be better.
Hi J.J.
The problem Im having is that the valve Im looking at only has two lines from the tractor a pressure and return and two lines going to cyd. the pb port is throwing me off
Hi J.J.
   / Add A hydraulic top link. #8
Can you show a picture of your hyd blk if you have one?
From your pump, you should have a pressure hose. Follow that and tell us what you see.
PB is simply a port that will handle high pressure. It could be on the hyd blk or on a hyd valve.
Do you see anything like Leejohn posted?
Hi Leejohn
I have got the part number for the block but it has 3 ports on the tractor a power , power beyond and return but I only need the power and return I don't know what to do with the pb port.
2019 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A52577)
2019 INTERNATIONAL...
2020 ANTHEM 64T DAY CAB (A54607)
2020 ANTHEM 64T...
2018 John Deere 470G LC Hydraulic Excavator (A53421)
2018 John Deere...
2017 Mitsubishi Mirage G4 Sedan (A53424)
2017 Mitsubishi...
JOHN DEERE BA84 WORKSITE PRO ANGLE BROOM (A54756)
JOHN DEERE BA84...
