adding a 3rd function valve to a 755 john deere HELP!
   / adding a 3rd function valve to a 755 john deere HELP! #21
Found this in owners manual- hydraulic 5.6 gpm , working pressure 2050psi
Excellent, any of the valve I linked will work great.
The parts from this kit should all be available from Deere if i wanted it to look factory ? Otherwise the diverter plug two 90s, two hoses, then i need the valve , and Q disconnects thats it ! Did i miss anything?
   / adding a 3rd function valve to a 755 john deere HELP! #23
The "factory" kit will NOT get you a valve to control your dump trailer-you will still have to add that. The kit is for powering a backhoe or logsplitter with it's own valve.
Right i understand that , do have any idea what ports to tap into? would they be the ones on top of the loader valve ??? and what are you suggesting i register for with JD parts , unless my dealer did it ? ( I doubt it ) AGAIN I OWE YOU BIGTIME ! , YOU JUST SAVED ME A BUNCH OF WASTED $$$:D
   / adding a 3rd function valve to a 755 john deere HELP! #25
I do not know specifically where the ports are-that is why I suggested finding a FSM. But they are probably on top of the loader valve...Maybe your dealer will copy some pages for you?
EDIT: I just looked it up-and you can get the technical manual on CD for only $55.00. Look HERE.
www.jdparts.com is a parts lookup system that is FREE to register at, it is the same basic system your dealer uses at the parts counter! Once you learn how to use it-it will be invaluable as you work on your own machine. You can even order parts online and have them shipped to your dealer for pickup. That is where I got the diagram's I posted from. Try it-You will like it. Just "think like a parts guy";)
Thank you again !, For spending your free time to educate the rest of us ! I spoke the dealer again, This time i got the parts manager and ordered what i needed and gave them an education too! Spent some time looking at the valve under the seat and have spoted the ports , looks like the seat has to come off
P.S. im all set up with that parts website, Thanks again!
2016 Chevrolet Caprice Sedan (A50324)
2016 Chevrolet...
2011 CATERPILLAR D9T HI-TRACK CRAWLER DOZER (A51242)
2011 CATERPILLAR...
2019 CATERPILLAR D5K2 LGP CRAWLER DOZER (A51242)
2019 CATERPILLAR...
2006 Ford Crown Victoria Sedan (A50324)
2006 Ford Crown...
Tennant S30 Ride-On Sweeper (A49346)
Tennant S30...
2014 CATERPILLAR 277D SKID STEER LOADER (A51222)
2014 CATERPILLAR...
