adding a snow plow to front of a 3320
   / adding a snow plow to front of a 3320 #1
sparker133
Green bay, Wi
2013 Deere 4320 cab, 180 loader, 485 backhoe, 2021 Deere 1023e, Vermeer trencher, 2022 Deere 26g
I have a 3320 and i just pick up a snow plow. I don't want to hook it up to the fel because of the problems it can cause. I saw a couple of guy mount it the front and used the loader outputs to control it. My questions are what size cylinders do i need, and what is the psi. Where do i get the quick couplers to hook up to the fel couplers. Also, were is a good place to get my part at a good price.
   / adding a snow plow to front of a 3320 #2
I don't know what the psi is but I do know you should be able to get the hydraulic fitting you need from tractor supply. The cylinder you are speaking of I assume are for power angling? If so it might be easier for you to use one double action cylinder rather than two regular cylinders. I know it sounds like it would not be as strong but it works fine. My friend had this setup on a 40hp Kubota and plowed with it for at least 6 years without any problems.
2025 Wolverine EX-66-84L Pallet Fork Extensions (A47484)
2025 Wolverine...
2025 Wolverine LL-12-78W Land Leveler Attachment (A47484)
2025 Wolverine...
2004 Ford F-150 XL Pickup Truck (A45336)
2004 Ford F-150 XL...
Ford F250 Flatbed (A45336)
Ford F250 Flatbed...
2019 Takeuchi TL8 Skid Steer (A47484)
2019 Takeuchi TL8...
Catepillar 914M (A46443)
Catepillar 914M...
