adding a thumb to Kubota KX-018
   / adding a thumb to Kubota KX-018 #21
I spoke with another Kubota dealer who advised me that Kubota has a valve available for this that vents excess pressure over to other side of cylinder and they use it on their thumb installations. OMG I have many hours into this with no success to hopefully have found a solution. I have ordered the valve and will install in when I receive. I will let you know once done.
Hey there this is a shot in the dark but I just came across this thread and had to sign up. I have a kubota kx018-4 excavator that I need to install a thumb on. I found a pin on factory connect model that I just purchased but I too have a pressure reduction dilemma. Is there anything you found out that you could possibly share, as far as the valve that kubota recommended for you? I spoke with my local dealer and to no avail whatsoever. One of the techs actually tried telling me it was not possible... I ended the conversation with them right there to say the least. Any help/information you could provide would be greatly greatly greatly appreciated. Thank you in advance!
-Matt
   / adding a thumb to Kubota KX-018 #22
Hi
Would like the results of installing dealer valve.
Did this this fix your problem?
Have photo of the install?
Part number used?
What pressure relief set to?
Thanks, Bob
2007 Peterbilt 379 T/A Day Cab Truck Tractor (A60460)
2007 Peterbilt 379...
2005 Cheverolet 2500 Pick Up Truck (A59814)
2005 Cheverolet...
2021 CATERPILLAR 299D3 SKID STEER (A60429)
2021 CATERPILLAR...
Ryan Walk Behind Aerator (A59228)
Ryan Walk Behind...
2006 iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A55853)
2006 iDrive...
Unused 2025 CFG Industrial QK16R Mini Excavator (A59228)
Unused 2025 CFG...
