adding brake controler to 04 ford f250
   / adding brake controler to 04 ford f250 #11
Soundguy said:
( 70$... hope it works ok.. cheapes one I've ever used was 99$...
If it does not work, or he does not like it...I will once again throw in my vote for the Jordan Ultima controller:
Best Brake Controller
   / adding brake controler to 04 ford f250 #12
Prob too late now but i like using the 3m double sided adhesive foam tape for attaching controllers to knee bolster on lower dash, clean att. surfacesfirst.
never tested this in florida heat but works in MI.
I tried hook and loop tape.. but controller kept puilling it off.. I ende dup just using the 2 self tapping screws it came with. Unit worked perfectly once hooke dup and mounted.
I did have to swap 2 wires around in the hoppy 7 pin to 6 pin plug adapter.. but then I had to do that to mine for my yukon as well.. 4 ys ago... for some reason they come wired wrong to work with electric brakes.... go figure..
Soundguy
   / adding brake controler to 04 ford f250 #14
Yep, remember our 2003 yukon, had to swap pins because pigtail was made for 99-2002 and gm decided to change locations for 2003 MY, prob cheaper for hoppy to add some print than put out two diff pigtails
Kent La Jolla Bicycle (A56860)
Kent La Jolla...
Brock 48'x16' Flat Bottom Grain Storage Tank (A57148)
Brock 48'x16' Flat...
2007 Capacity TJ6500T Wet Kit T/A Yard Dog Toter Truck (A55973)
2007 Capacity...
2015 Chevrolet Tahoe, 192,897 Miles, Decommissioned Law Enforcement Vehicle (A56438)
2015 Chevrolet...
2022 John Deere 4052M MFWD Compact Utility Tractor with 400E loader - Bucket, Forks and Grapple (A55314)
2022 John Deere...
25ft Tag Trailer (A56436)
25ft Tag Trailer...
