Adding Factory cab to open station
   / Adding Factory cab to open station #21
It listed under section 32 - CAB but it doesn't state what comes with it and I'll bet no wiring or AC compressor lines.
Part Number: LVA16958
Replaces Part: MIA10726
Part Price: 5,690.00 USD
Description: 3X20-4X20 CAB FRAME ASSY (DOM/EEC)
I can tell you from installing Hiniker and Year-a-Round cabs that installing a cab is a long way from an easy job
That is what I refereed to as the "shell".
   / Adding Factory cab to open station #22
That's fairly high $$$$$$$$ for a shell @ $5690. It's referred to as a CAB in the parts cat and it weighs Weight 665.99 LBS 302.09 Kg If that's not it then it must come out of Whole Goods not parts.
   / Adding Factory cab to open station #23
As I was blowing snow tonite in my 3720 factory cab I was thinking of this thread. How does the dash compare to a factory cabbed tractor. Would the glass still arch around the open station dash the same as a factory setup? Do the fenders match identical? (remember.... there are 2 doors to seal up;). WAY too many details like this and as others mentioned to really make it a feasable project IMO.
   / Adding Factory cab to open station #24
I agree with the majority in this thread, 7K for the cab plus your time and labor is alot of money, if it was me I would trade on a cabbed tractor.
   / Adding Factory cab to open station #25
I was looking at installing a aftermarket cab like a Laurin or other higher end cab but ended up trading instead.
2014 AMERITRAIL LAY FLAT HOSE TUGGER TRAILER (A58214)
2014 AMERITRAIL...
2006 iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A59228)
2006 iDrive...
2016 FREIGHTLINER  CASCADIA TADC (A59575)
2016 FREIGHTLINER...
MARATHON 25KW GENERATOR (A58214)
MARATHON 25KW...
Utility Cart (A59228)
DRAGON 500 BBL FRAC TANK (A58214)
DRAGON 500 BBL...
