Adding lights to a B3200
   / Adding lights to a B3200 #1
bullet3z
Bronze Member
Pa
I picked up a B3200 with FEL and I wanted to add 2 work lights to it. I am looking into the LED work lights that are available. So there will be no power issues with adding these lights. I will mount them on the ROP bar without drilling into it, if I can. My question is where to get the power supply from on these tractors? I will also be adding a lighted switch on the blank panel next to the drivers side arm rest.
I already changed the headlights out for LED bulbs. I will probably change the rest out as I go.
   / Adding lights to a B3200 #2
There is a power tap on the right rear of the tractor. if I remeber right it is on the same wire that goes to the right flasher. It comes with a ground eye and a bullet conector for power. It has power to it when ever the key is on.
Rob
2016 Dodge Charger Sedan (A46684)
2016 Dodge Charger...
3pt Ditcher (A47307)
2017 Peterbilt 567 Tri-Axle Dump Truck (A46683)
2017 Peterbilt 567...
2018 Generac MLT6SM-STD3 6kW Towable Light Tower (A45336)
2018 Generac...
2005 Cummins DGBB 43.7 kVA 3-Phase Diesel Generator (A46683)
2005 Cummins DGBB...
80in HD Tooth Bucket with Side Cutters ONE PER LOT (A48561)
80in HD Tooth...
