Adding lights to a B3200
/ Adding lights to a B3200 #1
bullet3z
Pa
I picked up a B3200 with FEL and I wanted to add 2 work lights to it. I am looking into the LED work lights that are available. So there will be no power issues with adding these lights. I will mount them on the ROP bar without drilling into it, if I can. My question is where to get the power supply from on these tractors? I will also be adding a lighted switch on the blank panel next to the drivers side arm rest.
I already changed the headlights out for LED bulbs. I will probably change the rest out as I go.
/ Adding lights to a B3200 #2
There is a power tap on the right rear of the tractor. if I remeber right it is on the same wire that goes to the right flasher. It comes with a ground eye and a bullet conector for power. It has power to it when ever the key is on.
Rob
Winco 12-Ton Fertilizer Tender Box (A66408)
Winco 12-Ton...
2024 JCB 35Z-1 EXCAVATOR (A65053)
2024 JCB 35Z-1...
Deer Staute (A64557)
1949 GMC 1 Ton Flatbed Original Truck (A65583)
1949 GMC 1 Ton...
2021 TORO MRTX2500 68138HD STAND ON CONCRETE BUGGY (A63276)
2021 TORO MRTX2500...
International box truck (A64194)
International box...
