Adding work lights
/ Adding work lights #1
agford4x4
Hempstead, TX
Case DX55
How many standard 55w work lights can i hook up to the existing electrical system of my dx55 without needed relays or extra electrical components?
/ Adding work lights #2
Under each rear fender of my tc55 i have a hot wire for a lite i would say two would be easy to hook up. The wires work by using the switch already mounted on the dash.
Yeah, i have those. I used one already for the optional work light facing the back. But can i add two more 55w work lights facing front? The reason is that the headlights are just about useless when you have your loader mounted unless the bucket is really low or really high.
/ Adding work lights #4
My friend Larry mounted 4 lights (55w ea) to my Kama during his visit earlier this year, for the same reason you are wanting. I have them pointing forward and backwards at a slight angle.
You can go here to check out the install... Adding Work Lights
They are wired with a heavy duty switch and their own fuse ... no relay. I don't do much night work but when I'm out in the field it lights up like a space ship. I figure their infrequent use allows enough time to charge the batteries back up.
/ Adding work lights #5
Not sure what the output of your alternator is but 3 more lights should not be a problem on a fifty five horse tractor ( unless it is renowned for bad electrics:p )If you are really worried about it you could use the circuit for your headlights and disconnect them since they don't seem to add much value with the loader on -- I have an old 135 massey that has the headlights removed completely and lights mounted on the outside brackets of the loader for that very reason. On my Jinma 284 I have welding magnet mounted 55w worklights that I plug into a lighter socket and it only has a 14 amp alternator:eek: -- has not been a problem so far
/ Adding work lights #6
I added a pair of 55w lights facing the front, using one of those existing wires for each light. Mine lights can spin towards the rear if I need light there. If I remember correctly, 3 lights push the factory worklight circuit over the limit since the front worklights are on there too. I plan on using the 12v accessory outlet for a mobile worklight in the future. You might consider that too.
/ Adding work lights #7
Forgot to add that I rarely turn on the regular tractor lights now with this set up. So I use the 4 instead of the stock two since they are on separate switches. This helps a bit.
/ Adding work lights #8
I have my lights attached to my highbeam light switch. I can have the regular lights on, or when I switch to the highbeams, my work lights turn on too. I just spliced the 55watt light wires into the headlight wires.
Eddie
/ Adding work lights #9
do you find that the lights have a glare in your eyes when you turn your head to the side?
/ Adding work lights #10
Not at all.
Did you see the pictures in the thread?
The lights are way up high on the ROPS canopy bracket so they are like 2 feet above me (or more). Since they are positioned to shine slightly to the sides, there is no glare at all. Now you should see what happens when I turn the regular lights on with the fel held low ... glare city!
/ Adding work lights #11
I had lights on the rops. My trees hated them though.. Oh well, dark is quitting time for me.. :)
For the light install, where did those brackets come from?
Also, is it OK to drill holes in the ROPS?
/ Adding work lights #13
there's a chance you might be over thinking this. you can get a 30 amp 12 volt relay at radio shack for about 8 bucks. run the relay trigger wire to the hot side of the ignition when key is on and you can run as many lights as you'll need. just use an inline fuse rated for the wire gauge and run and put it as close as possible to the battery.
if you want to go a step further, add a small fuse block with a heavy gauge wire to the battery or starter lead and you'll really be set to accesorize into the future.
amp
oh, and each 55 watt light draws 4.6 amps at 12 volts. (to answer your original question)
/ Adding work lights #14
My Kubota L3400 had a factory worklight circuit under the fenders but the gauge of the wire for these types of circuits is not usually big enough to support 4 55W lamps - 2 front, 2 rear.
With the help of others on this wonderful site, I was able to wire up a new circuit, fed from the battery, added a new fuse and relays. Not a terribly large amount of work.
You don't NEED a relay, so long as you have switches that can handle the load going through them. I put a relay in as both my sons are addicted to the tractor and will get on it when they can and flick all the switches they can find on and off. I didn't want to be stuck with a dead battery when it was time to blow the snow off the drive :)
/ Adding work lights #16
Ampsucker points out that each fixture will draw 4.6 amps.
Check your wire size and fusing accordingly.
If you have 16 guage wire (my guess) then 3 lamps would put you on the brink of heating the wire.
When you place a load on a wire that exceeds its ampacity, it becomes a series load in and of it's self. What kind of load? A heater.
Your fusing should protect your wire, but sometimes folks will bump up the fuse size and BINGO here comes the fire department.
So you must work within the limits of what is there or follow ampsuckers advice and run another circuit.
/ Adding work lights #17
yes, a relay provides extra safety and current capacity and is the only safe way to do it if you want everything on the tractor to be off when the key is off.
i also forget to mention in my previous post that the trigger wire coming from the key should be routed through your light switch unless you want the lights on every time the key is on. ;-)
also, no matter what you run, make sure you run the same size ground wire as you do a hot wire and that both are sized correctly for the load. fuse the conductor, not the load; size the conductor for the load.
amp
/ Adding work lights #18
I gotta second the comment about magnetic work light mounts. No holes to be drilled and you can move it anywhere you like. Ever since I fitted one to my bota, I have found it to be real handy to be able to move it around. I have mine wired into the tractor light circuit so when I switch on the lights, the worklight comes on. I fitted a marine 12v socket under the tractor seat that I can plug the work light into, and I have a curly cord running out to the light that extends out to ~10ft. In the pic I have it mounted out on the vertical top link post on my rear loader.
You got to watch out for the magnetic base though. I found the plastic lid of a Pringles tube fits perfect on my 3in magnetic base. Stops scratchin the paint. Not that my 20 yr old bota is pristine or anything but still, dont wanna add any more to the wear 'n tear if I can help it.. I got the mag base in NorthernTool.
I decided that i want the two lights to be on their own switch.
I see no need for them NOT to be directly connected to the battery. It also doesnt really matter if the key is off or not. In this case, they are two 'driving' lights from teh auto store, both 55w.
So, i shouldnt need a relay in this case. Now, what kind of wire should i use to get it to the battery? The switch i am going to use is hopefully going to match the rest of them because i have an open spot and it should be at least a 20a rated switch, which should be twice as much amperage as neede to run 2 55w lamps.
/ Adding work lights #20
you could get by with 18 or 20 AWG. i would go with 16 AWG as the voltage drop over a 10 foot run is only 7 percent giving you a load voltage of about 11.2 V at 10 amp draw.
16 AWG would also support a third light if you wanted to add it later with a 10% voltage drop.
fuse the conductor for 10 amps as close to the battery as possible to minimize the chance of shorting before the fuse protection. (ie pigtail off the battery only a couple of inches on the positive wire, fuse, then run to switch). if you want to add the third light, you could just upgrade to a 15 amp fuse and not have to rewire.
properly sized wiring will give you the most light output and safest rig. most of the little car fog light kits send the cheapest components available and the connectors, wiring and switches will be barely addequate and fail after the least amount of abuse.
also, use stranded copper wire, not solid core. solid breaks too easily when flexed repeatedly. solder and heat shrink your connections to make resistant to corrosion. ;-)
here's the chart if you ever need it:
American Wire Gauge table and AWG Electrical Current Load Limits
don't get mad the first time you forget to turn off you lights in the day time and you come out to a dead battery! ;-0
amp
2025 Mower King SSVR72 Hydraulic Vibratory Roller Skid Steer Attachment (A61572)
2025 Mower King...
2018 Chevrolet Silverado1500 Crew Cab Pickup Truck (A61573)
2018 Chevrolet...
UNUSED WOLVERINE HYD 6 WAY DOZER BLADE (A64281)
UNUSED WOLVERINE...
2020 John Deere R4044 Sprayer (A63111)
2020 John Deere...
2006 Cadillac Superior 6-Door Limousine, Ultra-Low 20396 Miles (A63689)
2006 Cadillac...
2017 Ford Escape AWD SUV (A61569)
2017 Ford Escape...
