Additive to keep plow from freezing
   / Additive to keep plow from freezing #11
Yep, low temp snowplow pump oil. Works wonders!
Got the plow oil with anti-freeze but just too cold and windy to work outside today. Going to -23* tonight.
Will be 6* Tuesday and only 10 MPH winds. Will likely do the fluid change then and report back on how the stuff works.
   / Additive to keep plow from freezing #13
My plow would freeze up at the first driveway I did everytime. I used about 2 gallons of hot water on the valve and cylinders and it would work fine the rest of the storm.
   / Additive to keep plow from freezing #14
I use Shell aircraft hydraulic fluid. -20F or lower...no problems.
2010 LAREDO 5TH WHEEL (A55745)
2010 LAREDO 5TH...
2022 FORD F-250 STX CREW CAB TRUCK (A59823)
2022 FORD F-250...
5ft Kobalt Toolbox with Key (A57454)
5ft Kobalt Toolbox...
MINI SWEEPER ATTACHMENT (A56860)
MINI SWEEPER...
Kubota B2601 Utility Tractor (A57453)
Kubota B2601...
2005 Volvo VNL Truck, VIN # 4V4N19TG25N374995 (A57453)
2005 Volvo VNL...
