Adjust 3-point lever… is it possible?
   / Adjust 3-point lever… is it possible? #1
S854
Platinum Member
Helena, MT
‘67 MF 135 Deluxe / ‘22 Kioti CK2610 HST/Bad Boy ZT Elite 54”
My tractors 3 point lever is labeled 0 - 10… with 10 being fully raised…
Problem is, between 0 and 7 nothing happens out back… so 7 thru 10 is the range that raises/lowers the implements… rather abruptly…
I’ve watched the lift arms without anything attached… nothing happens… so it’s not the weight of any implements that’s causing this behavior…
Is this something that’s adjustable somehow?
   / Adjust 3-point lever… is it possible? #2
It sounds like you have draft control on your Kioti, but I don't think they offer it on that model. Since you don't, I would think that the position rod on the 3pt arm that senses the position of the hitch for the 3pt valve is out of adjustment.
It sounds like you have draft control on your Kioti, but I don't think they offer it on that model….
Correct… I have draft on my MF135, so I know what that does… no draft on the Kioti…
… I would think that the position rod on the 3pt arm that senses the position of the hitch for the 3pt valve is out of adjustment….
I’m not familiar with a “position rod”… is that something exterior on my tractor? If so, how do I identify it? Better still, how do I adjust it?
Thanks
   / Adjust 3-point lever… is it possible? #4
My Kioti is the same. 3pt does not use full range of the lever.
Looks like an engineering issue, to me. Not something that can simply be adjusted. The lever fulcrum point is not built correctly.
   / Adjust 3-point lever… is it possible? #5
Thanks
This is an illustration of a 3pt position rod, #53 & 54. It is connected to the lift arm and tells the hydraulic system where the lift arm is positioned. It can be adjusted so that the 3pt quadrant responds correctly.
Again, I don't know what Kioti does, but this is what I would look for to change that range problem.
If it doesn't have that, then the quadrant assembly should be adjustable by loosening the bolts that secure it to the top cover and rotating the quadrant piece.
Anyway, there should be an adjustment, but I have no access to a Kioti or a parts/service book to look at to help.
   / Adjust 3-point lever… is it possible? #6
Mine uses the full range and is pretty much infinitely adjustable from 1-10.
When I get a chance, I will look and see where the adjustment can be made. Or if it can..
Been out inspecting the 3 point…
Unfortunately the only thing that moves when the lever is moved is a connecting link (position lever to shaft), the shaft (which rotates and disappears into the rear casting) and the lift arms…
   / Adjust 3-point lever… is it possible? #8
See f you can disconnect that from the PTO handle and make sure the lever can move through it's full range of motion. Also make sure the shaft can move though *it's* full range.
   / Adjust 3-point lever… is it possible? #9
Dose the connecting link have an adjustment?
A couple of pictures would help if someone here with a Kioti doesn't chime in first.
Funny you should say that… I was looking at the connecting link today (no adjustment) but I am considering bodging something together akin to a turnbuckle…
Don’t want to modify the original link in case this “experiment” doesn’t yield the desired results…
I’ll get some pics as I go along…
2023 WRANGLER 5500T ARTICULATED WHEEL LOADER (A58214)
2023 WRANGLER...
Kubota L3130 (A53317)
2018 Chevrolet Tahoe SUV (A59231)
2018 Chevrolet...
Husqvarna Riding mower (A56857)
Husqvarna Riding...
2017 BX2680 Sub Compact Utility Tractor (A56436)
2017 BX2680 Sub...
24in excavator tooth bucket (A56436)
24in excavator...
