When adjusting the injection timing, I have a few suggestions.
1 Remove the radiator. It's simple to do, drain it into a bucket, remove two nuts on the bottom, pull the retaining clip at the top, remove a couple clamps and it's off.
2 Spend some time cleaning up the timing marks on the crankshaft pulley. Maybe wipe some white or yellow paint into the marks with a paper towel or cloth.
3 Its important that the compression release is on any time the crank is rotated during maintenance so the engine doesn't fire unexpectedly. Use a piece of pipe a about 1 1/2 or 2 feet long on the ratchet handle to turn the crank pulley. It's not hard to turn the pulley but the long handle will give you a great deal of control and accuracy when turning it. A couple degrees of pulley rotation will be a few inches at the end of the pipe.
Turn the handle and watch for the fuel to rise in the first fuel port. Once you see it begin to rise, stop and look at the marks. If it's other than 16 degrees (or whatever your manual specifies) , try it a couple more times to make sure you're reading it correctly. Then an only then should you consider changing the timing. If you do need to change the timing, everything is accessible since you've already removed the radiator.
One of the posters in this section mentioned (implied?) that valve lash is the adjustment of valve timing. Actually, valve lash adjustment isn't an adjustment of valve timing, it's the adjustment of the clearance between the cam lobe and the valve stem. This affects how much play is present between the rocker arm and the valve stem. This in conjunction with the height of the cam lobe and the pushrod rocker geometry determines how far the rocker arm opens the valve or in the case of no clearance or an over tigthened adjuster, whether the valve will actually close. The duration of open time of a valve is determined by the width of the cam lobe. While a severely misadjusted valve adjuster will alter duration, it will also beat the valve stem and adjuster screw to pieces. While there is a tiny but insignificant change in timing, valve lash adjustment is not intended to alter valve timing. It’s to maintain the proper clearance between the rocker arm and the valve. As the valve heats up, it lengthens, so some clearance is necessary. If it has too much clearance it’s noisy and will damage the adjusting screw and or valve end. If there is too little clearance as the valve lengthens (from heating), it will cause the valve to remain open and the proper compression pressures won’t be achieved and combustion for that cylinder will fail.
Valve timing is the position of the cam lobes on the cam and their position with respect to the crankshaft. Valve timing is changed by shifting the sprocket or gear on the end of the cam shaft such that the cam opens the valves at the desired time with respect to crankshaft position. This is sometimes called “degreeing a cam”. Depending on the performance desired, the timing can be advanced or retarded. This will result in altering the torque and horsepower production of the engine.
While I haven't personally verified this, I'd be willing to bet that the valve timing on Jinma engines is fixed and keyed at the factory (cam drive gear can’t be shifted).
