crash325
Elite Member
So buy some 60-40 or 40-60 un-coated silver solder and buy the flux seprately. Will flux for plumbing soldering work ? Cause I have a tin of paste already.
Also easy=melts at lower temp,... and hard = needs higher temp? correct.
Next a tank of mapp and my propane torch head will work fine?
Just trying to pare all this down into a list as I will go shopping tomorrow. I will try to look up a Lapidary supply in Bangor Me on the web to see if there is one? Thanks for the advice.
Hi,
Plumbers solder is lead solder, it's flux will not take the higher temp of silver solder.
Battern's flux a liquid works real good and most lapidary supply's will have it. Other brands are probably just as good.
A paste type is even a little better if they have it.
Get easy or low temp silver solder, depending on the brand its about 60% silver & 40% copper, with a few traces of wetting agents.
Generally silver solder is sold by the gram (31.2 grams per ounce.) or DWT ( penny weight = 1.55 grams). 1 or 2 grams will last you a long time.
The small hold the tank type of torch is all you need. Do most of your heating from the opassit side of the actual joint. When flux turns clear move to the top. & heat around you little brass item.
You may want to practice on some scrap, then if you have problems, talk to me and explain them.
Jim
