Advice on deck cleaning and blade changing
   / Advice on deck cleaning and blade changing #11
Some of you guys might be able to clean the snot from under your mower decks the way I do. Every spring I chip a LOT of small pines. I have GREAT piles of pine chips all over the property. I drive my JD G100 mmm up and on top of a pile of chips. Fire up the blades - lower the deck.
The first time I did this - WOW - what a wild sound. Wood chips flying everywhere. About five minuets of this - the underside is clean a a whistle. The pine chips do no damage to the blades.
Change the blades - long handle ratshit wrench and a whole lot of grunt.
   / Advice on deck cleaning and blade changing #12
I have a chipper. That is worth considering. Pretty big chips and chunks though.
   / Advice on deck cleaning and blade changing #13
Yard and lane take about 4 hours to mow and is far from smooth or level. There are some significant side slopes as well.
I know that mowing while the yard is damp isn't the best, but at times I don't have much choice.
Currently have a Husqvarna GTH52XLS that I have to pull the deck in order to clean and change blades. This wasn't too much of a problem in the past, but due to injuries I now have limited mobility.
I've been considering a ZT or a front mount with a 'flip up deck' to make the job easier.
Any advice would be greatly appreciated.
Oh yeah as for changing the blades the only way to go is impact wrench and a 2x4 to hold the blade.
   / Advice on deck cleaning and blade changing #14
I too only clean my decks at end of season or if I have the deck off and up in the air for a blade issue. And then only a cursory cleaning.
I think mine are usually "cursory" cleanings too. Usually I'm standing there cursing "Why did the :censored: wife mow the g*d d*mm wet grass, then leave the :censored: mower caked with 3" of sh#t for me to clean when all she had to do was wait 2 :censored:ing hours ?!" :rolleyes:
   / Advice on deck cleaning and blade changing #15
Many thank oosik, for the 'pine chip' cleaning mention. I had been wasting my time in the past with a scraper, cleaning the under-deck of my GTH26V54LS, and all the time I had little piles of wood chips laying around.
Earlier this week I had to mow wet grass. Deck was caked up something horrible. In less than 3 minutes, letting the mower run while on top of one of the wood chip piles, it was as clean as a whistle! Your suggestion is right on, and a major time saver. THANK YOU, again.
PS A nice side benefit is that the wood chip pile quickly gets turned into very fine chips; better for flower bed covering.
   / Advice on deck cleaning and blade changing #16
Erda, the "entry level" commerecial ZTRs will make your life so much easier. I was mowing 4 1/2 acres with a JD3320/72" belly mower and am now mowing in 1/2 the time, trim around trees and with a cleaner cut. My choice was a Ferris ISX800Z ZTR 52" deck which mows a 3" cut in 5" or so grass at 8mph. Cleaning the blades or changing them I just pull the FEL up, add car jacks for safety. Using an impact wrench and 2x4 sounds like a good idea I will have to try. Good Luck
   / Advice on deck cleaning and blade changing #17
Hustler makes a flip deck ZTR but I wasn’t a big fan of the idea. Apparently most others weren’t either because the local dealer stopped carrying them. If that feature was important I’d have a Kubota F series or a Grasshopper front deck. I have a ZTR mid mount mower and it’s not hard to deal with. I use a floor jack or a loader and lift the front and put a jack stand under it. Spinning the blades off with a cordless impact takes about 30 seconds. The deck hardly ever needs cleaned. I usually hit it with a pressure washer a couple times a year.
   / Advice on deck cleaning and blade changing #18
I use a mower/ATV lift you can get from Harbor Freight for about $75. Also use a cheap air impact wrench to remove blades.
   / Advice on deck cleaning and blade changing #19
I put a chain on it to my loader and lift it almost vertical..
   / Advice on deck cleaning and blade changing #20
The cleanest I ever got the deck on my F-935 was to mow down a bunch of willows that were about 2 feet tall and had been burnt the previous fall. The burnt willows were dried out and when I went through with the mower they cleaned off all of the stuck on grass.
Yeah ... seriously --- You can pile up a bunch of small tree trimmings and mulch them. Win win ... Rather than work hard in lieu of smart.​
2013 Ford Escape SUV (A50324)
2013 Ford Escape...
2015 GMC Yukon XL Denali SUV (A50324)
2015 GMC Yukon XL...
40' CONTAINER (A51244)
7616 (A47384)
7616 (A47384)
(10) 28' Continuous Fencing Panels (A50515)
(10) 28'...
2013 Ford Taurus Sedan (A50324)
2013 Ford Taurus...
