SPYDERLK
Super Star Member
- Joined
- Feb 28, 2006
- Messages
- 10,381
- Location
- VA
- Tractor
- JD2010, Kubota3450,2550, Mahindra 7520 w FEL w Skid Steer QC w/Tilt Tatch, & BH, BX1500
Joe1, yes the voltmeters would put a very smalldrain on the batterys - so small that it is not worth considering on that size of battery. Batteries should be charged occasionaly even when not in use because they self discharge about 5% a month due to internal leakage. A voltmeter added to this might increase it to 6 or 7% a month. Normal charging regimen of once a month for an idle battery with voltmeter on it would be plenty. And if youre using the cart the metersare a constant reminder of battery health by showing you how well they maintain V under load.Joe1 said:spyderlk:
Connecting a voltage meter without an on/off switch will put a constant drain on the batteries. I assume it will not amount to much on a 36 Volt cart unless it sits for months, then the batteries would lose power anyway. Am I wrong on this assumption?
It seems to me that if accessories are hooked up to a pair of batteries, then the easy way to charge them separately would be a solar panel mounted on the roof of the cart. This may or may not keep ahead of the drain but it would keep that pair closer in power to the others. An expensive way to charge just the two.
A battery operated portable radio would provide the music without draining any pair of batteries.
Are the lights on carts connected to just two batteries or to all six thru some stepdown transformer
My lights are 12V and are powered by just 2 of the six batteries. Transformers dont work on DC so use of the whole pack is not an option without electronic sophistication. Anyway, unless lights are used a lot the batteries supplying them will be ok between charges AND you will be able to keep tabs on their relative discharge with the voltmeters. Its really only the heavy sustained drains, like from an inverter that will require special attention and again, a trio of meters provides the info for you to act on. Probably no special attention necessary other than more frequent standard charging of the full pack and maintaining correct electrolyte level, and occasional rotation of heavy 12V loads to other battery pairs.
Larry
