grizer
Eddie, I've kept up with your work and planning since the start, good job! You have overcome several things by logic and hard work.
NOW, Golf carts. For least problems, least money spent, most use and long life. There are good posts above with good advice.
1. EZGO, 36 volt. no big tires, no lift kit, plain jane, best bet in long run, will climb hills and pull carts very well.
2. Battery condition guage, to tell you when to turn around and start home.
3. Sun top or shade, windshield and vinyl cab if needed in winter.
4. As stated in posts, wash with soda and keep batteries filled with distilled water. Keep terminals clean and repaired, larger wire is good.
5. Now to what is best for batteries, The nearer full charge you can keep a battery will give the best life. A battery that is partly discharged, will sulphate more, the longer it sits, the harder and longer you have charge it to bring it back to full charge because of sulphation. This is true for deep cycle and regular. Keep automatic charger plugged in at night or when not in use. A good automatic charger will tell you when you need to replace batteries, it will come back on often and it will be hard to keep water in batteries. All batteries will need to be changed at one time, period.
6. A 36 volt EZGO with fresh fully charged batteries will go almost 20 miles.
7. Any added accesseries cost performance and run time.
