Advice on planting trees.
   / Advice on planting trees. #21
You need to dig a test hole and find out if you have any hardpan (dense clay) layer within 3 feet of the surface. You'll lose your trees if the roots can't get to groundwater because of the hardpan.
If you have hardpan, you either need to rip the soil in your spruce orchard with a subsoiler that's generally pulled by a Cat bulldozer. That's how the professional orchard growers around here do it. You can use a post hole digger with an 18" dia auger to punch through the hardpan. Or use a backhoe to dig a trench to get below the hardpan layer.
Good luck.
UNUSED LANDHONOR LHR-SP50 HYD SHOP PRESS (A54757)
UNUSED LANDHONOR...
2011 JACK 130BBL (A53843)
2011 JACK 130BBL...
2000 PETERBILT 357 6X6 DAY CAB ROAD TRACTOR (A51406)
2000 PETERBILT 357...
Pitts Tri-Axle RGN Lowboy Equipment Trailer (A50322)
Pitts Tri-Axle RGN...
UNVERFERTH 210 LOT NUMBER 16 (A53084)
UNVERFERTH 210 LOT...
2011 MERCEDES-BENZ S-Class Sedan (A53424)
2011 MERCEDES-BENZ...
