Aftermarket terramite cylinders
   / Aftermarket terramite cylinders #11
Cant nyone. The cylinder off off and the rod broken.
   / Aftermarket terramite cylinders #12
Use a comealong to pull it up. Im sure you can find dimentions on full height of bucket or loading height. Get it to that point and take a few measurements. Going by some 3rd party knowledge on the Internet is iffy at best.
   / Aftermarket terramite cylinders #13
I measured the old cylinder. Fully extended id 46 1/2". The bore is 2 1/2", the rod is 1 1/2", the pins are 1". It worked alright.Maybe Ill just order one that size.
   / Aftermarket terramite cylinders #14
I wouldnt order a cylinder based on the fully extended dimention alone. You most likely spend more time at full boom up when loading a truck or something. Having both would be real handy when you order a new cylinder.
Surpluscenter.com has a prety good selection of cylinders.
Its hard to believe you bent a 1.5in rod with only 2.5in bore. Do you know how it happen?
   / Aftermarket terramite cylinders #15
nope.I loaned it out and thats how it came back.
   / Aftermarket terramite cylinders #16
Nice work! I believe this would work. However, they are out of stock until September. I'll probably wait and order when they have stock.
Thanks!
Do you happen to still have part # ? I can't find this one and need one. Help a old man out who doesn't understand all this stuff. THANKS
   / Aftermarket terramite cylinders #17
I just happened to be looking at this thread because I recently had to replace the seals in the curl cylinder on my T5C. The seal kit cost me $69 and took the better part of a day. My hose fittings were so tight to the cylinder that I gave up and just worked with the cylinder on the machine. Then there are two seals on the piston that I had to heat in hot water to make pliable enough to install. Overall, not the easiest job.
I also happened to notice this review on Amazon where someone bought an aftermarket curl cylinder for about $100 shipped and then had to convert the fittings. But he got a new cylinder and didn't have to mess with changing the seals. https://www.amazon.com/gp/customer-...ef=cm_cr_dp_d_rvw_ttl?ie=UTF8&ASIN=B009PJELO8
   / Aftermarket terramite cylinders #18
A 2in bore, 16in stroke and 1in pin size cylinder is prety standard. Converting from SAE Oring to what i assume is NPT is simple and can be done for cheap.
I wouldnt mess with a seal kit if the cylinder wasnt something special and a new being so cheap.
EZ-GO Utility Cart (A55853)
EZ-GO Utility Cart...
Ingersoll Rand SD-116DX TF (A53317)
Ingersoll Rand...
Eagle Weathervane (A55853)
Eagle Weathervane...
2021 Liebherr L556 (A53472)
2021 Liebherr L556...
2018 Toro Workman GTX Electric Utility Cart (A55851)
2018 Toro Workman...
2016 PETERBILT 579 (A53843)
2016 PETERBILT 579...
