Ag tires vs R4
   / Ag tires vs R4 #11
Just a bit off topic...but...
What would it cost to change out tires IF you discovered you wanted the "other" choice??
My land is mostly woods with 3+ acres of field that I plan to brush mow. Also will brush mow 1+ miles of trails and generally work as a tree farmer in my 120 acres. On one hand I want top traction for when I try to cross a damp gully...on the other hand I like the toughness of R4s driving over "stuff" in roughed out forest. I currently do not plan on plowing...or maybe even using...in the winter...but won't rule that out down the road.
Sooooo...approximately what would it cost to change out the tires on say a 35-45 HP size tractor...I know you can only estimate...but I have NO idea. :)
Thanks...Tom R
   / Ag tires vs R4 #12
No such thing as "good as", both R1 and R4 have their strengths/weaknesses, figure out what you do most and buy accordingly. I have R4 on my L5030 and R1 on my M8540, both work well for how I use them.
   / Ag tires vs R4
I have a 2 bottom plow and a 7' 6" disc . tractor is 50 hp . From what I hear it should be ok but better with ag tires . Dealer does not have the ags.
   / Ag tires vs R4 #15
Like everyone else said it all depends on what you use the tractor for. I'm glad I could convince my dad to get the R4's on the BX25 instead of turfs. ;)
   / Ag tires vs R4 #16
Depending on type of ground use.
As other gentlemen said I agree,but for me somewhat flat field mowing,snow removal,driveway repairs etc. I like R4's.
   / Ag tires vs R4 #17
Pretty good posts here so far. I have R4's on the JD and since that sees some turf duty I prefer them on that. Have never been stuck yet despite being in some pretty gooey spots. They work fine.
Have ags on the McCormick, of course being a utility tractor that is to be expected. FANTASTIC traction but stay away from the lawn with them.
   / Ag tires vs R4 #18
Tom R.,
I think that with the duties you describe, R1w's would be a good choice (like the Michellin XM27)
I just put those on the front of my 5030, and have not yet gotten the bill but I think that they run about $500 each. I intend to switch to similar for the rears when they need replacement. Using the MFWA with lots of FEL work creates substantially more wear on the fronts; the rears will last for quite a bit longer.
   / Ag tires vs R4 #19
Sir,
If you are going to pull that plow I would strongly consider the R1's or R1w's.
AG Ground engagement duty is what R1's are designed for. The dealer may not "have" them, but the dealer can "get" them if he wants the sale.
   / Ag tires vs R4 #20
Tom R.,
The XM27s do look good...that may be a good choice...also I understand the front first option...Tom R
2004 EAGER BEAVER 50GSL/3 DETACH TRAILER (A52707)
2004 EAGER BEAVER...
TEST YOUR BID BUTTON! (A52709)
TEST YOUR BID...
CLAMP ON UNIVERSAL 42" FORKS (A54757)
CLAMP ON UNIVERSAL...
1995 Ford F-250  7.3L Powerstroke Diesel (2WD, Long Bed) (A55315)
1995 Ford F-250...
2017 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A57880)
2017 FREIGHTLINER...
2019 Krause 8005-30 Excelerator - High Speed Vertical Tillage - 30 FT Working Width (A55315)
2019 Krause...
