Agco 2027, Kubota GR2100 or BX
   / Agco 2027, Kubota GR2100 or BX #12
bx24d said:
I'm looking at the Agco 2027 4wd, Kubota GR2100 4wd and BX 1850 or 2350 for mowing my hilly 2.5 acres.
1* I have a CUT for larger jobs like brush hogging.
2*Wondering if anyone has experience or opinions on these three models.
1*Since you have a cut I'd strike the 2350 and Agco 2027 from the list and go for the smaller 1850 since you don't need the larger 2350 & Agco 2027 if mowing is all you plan to do.
2*I have 2 BX1500s which are simliar/comparable to the bx1850.No way would I consider trading them for a gr2100.
My BX23 is the same as the BX2350 except for the Back Hoe. If I was going to mow your place I'd use the BX1500 rather than the BX23.
The BX1500 pucker factor is less on slopes than the BX23s.
Matter of fact I mow some areas with the BX1500 that you couldn't get me on with the BX23.
One more note the BX1500 ROPS is much shorter than the BX23 ROPS.
   / Agco 2027, Kubota GR2100 or BX #13
LBrown59 said:
Exactly why I own 2 BX 1500s instead of 2 lawn or garden tractors.
You have 2 BX1500s? No kidding, really? You should let more people know!
I've measured the rops on the 1850 and the 2350 and they are within one inch of eachother. rops height and foldabillity is a concern for me when mowing (I've got a few trees to get around). Agco comes with foldable rops option, bx 1850 and 2350 can be outfitted with the bx24 foldable rops, which is very high even when folded. Becauseof my hills, I'm looking for a foldable unit that is fairly low when folded.
   / Agco 2027, Kubota GR2100 or BX #17
LBrown59 said:
The op wanted to know about my experiences so how do I tell him with out saying what I have ? Double DUH
You have it in every post you make....look below:confused::p :rolleyes:
Tractors
2003 Kubota BX1500/2004 Kubota Bx23/New- Kubota BX1500
60'' Front Blade/48'' Rear Tiller/FEL/Back Hoe /60'' MMM/Clamp on Forks/48'' MMM
   / Agco 2027, Kubota GR2100 or BX #18
Tractors
A lot of others list tractors and implements in their signature.
Ok now what else is new?
:confused:
2019 FORD F-150 XL SINGLE CAB TRUCK (A51406)
2019 FORD F-150 XL...
2025 New/Unused LandHero 16in Concrete Cutter (A51573)
2025 New/Unused...
Bobcat 14" Hydraulic Asphalt Plainer (A52384)
Bobcat 14"...
(4) 55 Gallon Drums of Bonderite (A51573)
(4) 55 Gallon...
2013 XLR THUNDERBOLT 35X14 5TH WHEEL CAMPER (A52472)
2013 XLR...
