Ags or turfs on your beaver?
   / Ags or turfs on your beaver?
Your new tires look great, and it appears you have gotten a lot of work out your machine. Nice job! Did you notice any difference in the tire size while operating the machine?
no...if anything it is a little better, in high range, 1st is more useable instead of the "granny" gear... the biggest thing I notice is it just goes... Night and day difference between unfilled turfs and filled R1's... the power range might just be my imagination thinking it was different....idk.
here's some of the update pics...
anywho, got a bunch done with the great weather we had the last couple weeks. Now, I need to finish my loader, get tons of topsoil and rent a trencher to run drain tile.
back yard.... I ended up taking about 3 to 3 1/2 feet out of the back cornerwhere the fence and the garage meet. I spread it out beside the garage creating a taper to the back corner. The property slopes to the left, so I"m going to run drain pipe down the width of my property and end it at the opposite corner to the low point of the property ditchline.
Now, I had a bigger issue in the front yard too...Did the same thing...tore my my yard up, dug out the muck, let it dry out, then went back and moved material to higher ground. Added a sloped grade, from the center of the property to the ditch. this is basically what I started with...soggy, stayed mushy all year round... this pic is just from driving on it a few times..
I think I hit bedrock!!! :Orange_tr
Here's a quick phone vid of me draggin some dirt.... click on the pic, not sure why it doesn't have the play button....
I'm not totally done, but had to button it up before the rain came...I had to move my topsoil pile to the left in this pic about dusk as the storm was moving in. It all got spread out on this side of the house, about center of the red fence in all those low spots in the pics. That was difficult doing that in the dark, as it started to rain, but I was amazed how smooth she turned out! I had a bucket sitting outback that had 2"of rain in it the next morning... no pond or swap in the front or back yard where there was before.... I didn't take any pics the other night because it was dark, and just plain forgot today, but I'm mostly finished with the rough grading...need a bunch of fill dirt next (and a loader to move it). I'm thoroughly amazed at this little tractor. i worked the dog snot out of it, and it took it like a champ. Might be the best 800 bucks I ever spent! I'll try to get a "finished" pic of the front yard if I can get home before dark tomorrow!
Best part is....... After I was done in the muck, I got my matching front ags! lol. Had it get a little warm on me and I ended up taking the radiator in to get cleaned and they found a pinhole.. . put me down for two days in this 80 degree weather weve had.... New belts and hoses and cleaned up the engine and repainted some on it.
here are a few after shots.... not totally done, still have to get tons of topsoil/fill and spread it out and dig some drainage trenches for the drain pipe. I'm excited there wasn't standign water in my front yard like there was last year!
Michelin CARGOXBIB High Floatation Tires (SET OF 6) (A55301)
Michelin CARGOXBIB...
2012 Chevrolet Cruze Sedan (A53424)
2012 Chevrolet...
Skid steer auger plate (A50322)
Skid steer auger...
2019 FREIGHTLINER CASCADIA SLEEPER (A54607)
2019 FREIGHTLINER...
2021 FORD F-150XL CREW CAB TRUCK (A51406)
2021 FORD F-150XL...
1996 JLG Commander CM2033 20ft Electric Scissor Lift (A51691)
1996 JLG Commander...
