Air Cooled Diesel Engine
   / Air Cooled Diesel Engine #51
I worked of Deutz diesels for 6 years. A lot of gen sets, pumps, but we put a few in a box type truck(UPS, Fed-ex type), a non turbo 5 cylinder in there. Still more in some big Poclain hoes. Atlas Copco and IR compressors, Ditch Witch used them in many machines. Even had a guy drive up one day with a V-12 in a White Freightliner! If I recall he said in the hills it would outpull the other guys, but didn't have the engine braking.
You can get an air cooled in a smaller package, smaller package can mean less costs all the way around. Not sure the big deal about the oil sprayers under the pistons. I have seen them on other engines to. Whether sprayed or splashed, oil is used to cool the underside of a piston. On the 912 series (ditch witch size), the fan was belt driven, a cut off switch would kill the motor if the belt broke. The 413 V series had a centrifugal hydraulic drive fan.
The only overheat or melt downs I had were caused by using the engine in the wrong spec. One expensive one I remember was a very large over the road crane(max boom was over 500'). Just shipped it in from Germany to New Orleans. Smoked the motor entering Texas. The fuel pump was designed for intermiting loads while driving around europe. They got on I-10 headed to Houston where it is flat. We replaced the motor after recalibrating the pump.
A couple of yall mention the one cylinders. Funniest one there was I got a service call to the Houston Heights area. Figured it was a construction site. Nope a house, lady answers the door, then points to the sail boat in the back. A hand start single cylinder Deutz to power around if needed. Which isn't as bad as it sounds, to keep the single cylinders running smooth, they (and the 2 cylinder) had a huge flywheel. They always shook like crazy until you got the rpms up. Not that hard to start with a ratching compression release and crank.
As far as overheating, this past summer some neighbors at the weekend place were putting in some water pipe, about a mile of it. Rented this beater ditch witch. I think they ran it 8-10 hours solid. Oh and being a mechanic I noted there there was no side cover on the Deutz to force the air between the pistons. Didn't care, came that way. It's probably still missing that cover today! And still running. Wouldn't that be the same as running with no water?
With the individual cylinders I think it was easier to work on. Parts were lighter and easier to handle, only had to replace a single cylinder if needed, not bore the whole block. Fuel pumps were a nice Bosch. The smallest one with a turbo I saw was the 6 cylinder 913 series. Most were direct injection but the W series had pre-combustion chamers, used mostly in mines, they were down on the power.
As someone mentioned they could not get the epa rating are/were phased out. There are still a lot of them out there running that I see all the time.
I have a SAME Explorer 90Turbo that has been mainly used digging fence post holes and moving hay in the winter. However, this year we had to use it in the hay field running a 7ft disc cutter. It is overheating in less than one hour, loosing power and the tach has stopped working and the battery light is now on. The motor fins are clean, all fluids were just changed but still same result...overheating. Any thoughts?
   / Air Cooled Diesel Engine #52
   / Air Cooled Diesel Engine #53
I am not sure but I think this could very well be more than one problem. There are a few reasons as to why the engine would be overheating besides from internal problems.. The fins as you say need to be clean and are very hard to if you have had a oil leak on say one of your rocker covers.. The second is that i am assuming your fan speed is ran by an exhaust gas thermostat.. When this plugs up your fan speed slows due to less oil flow but will most likely bring on your oil pressure light.. The third is that the fan is ran by oil pressure so if your pump is dodgy then you wont get enough fan speed.. If you want to speed up your fan and not use the exhaust gas thermostat you can remove a little bolt on the side of it and remove the washers on it.. Replace the bolt into the thermostat and fan should run full speed all the time.. Make sure there is lots of air coming out between cyinders and out transmission cooler.. I would change fuel filter and make sure there is no water in fuel.. Hope this helps a little
   / Air Cooled Diesel Engine #54
Hello Good people,
I have a SAME Solar 60 with a damage engine. Currently sourcing for the same Engine or any other that can fit. I will really appreciate any info on this. Thanks.
   / Air Cooled Diesel Engine #55
Does anyone know a source for 10HP Yanmars (or clones) with the SAE J609B tapered shaft for bolt-on generator heads?
   / Air Cooled Diesel Engine #57
Hello Good people,
I know where there's an entire good running Vigneron 60 for $3,500.00, if that would help...
SR
Pratt 8.5ft Flatbed Tilt Trailer (A55787)
Pratt 8.5ft...
MACK T/A DUMP TRUCK (A58375)
MACK T/A DUMP...
Peterbilt Tandem Axle Road Tractor (A47477)
Peterbilt Tandem...
2020 MACK PINNACLE (A58214)
2020 MACK PINNACLE...
2019 ALLMAND BROS, INC. ALLMAND BROS, INC. (A55745)
2019 ALLMAND BROS...
UNUSED PAIR OF MINI RUBBER TRACKS (A52706)
UNUSED PAIR OF...
