Air in hydraulics?
   / Air in hydraulics? #1
oleoacres
Mahindra 2310
Hi - somewhat of a novice here.
I have a Mahindra 2310. I had a hydraulic leak on a rubber boot on the right brake rod, and I lost a lot of fluid. I replaced the boot and refilled the hydraulics (about 4 gallons), but the hydraulics aren’t working as they should.
Before the repair, I had no steering, and neither the bucket or the hitch would raise or lower. After the repair and filling, I have a little steering, and I was only able to raise the bucket a few inches.
I’ve read that some hydraulic systems are self bleeding - is that the case on mine? I’ve spent enough time messing with the controls and steering to believe it isn’t just going to fix itself by bleeding air out automatically.
Any tips for getting the hydraulics working again?
   / Air in hydraulics? #2
Try loosening the lines on top of the pump a few turns. Then briefly starting the engine and watch the lines for oil spewing out. If/when it does, shut the engine off and tighten the lines. Sometimes that needs to be done.
Ok, thanks. I’ll try that.
Toyota 7FGCU25 5,000 LB Cushion Tire Forklift (A59228)
Toyota 7FGCU25...
2023 New Holland CR10.90 Combine - 330 Engine Hours - 251 Separator Hours (A56436)
2023 New Holland...
UNUSED RAYTREE RMPP680 HYD POST POUNDER (A60432)
UNUSED RAYTREE...
Hays LT1 Tender (A61307)
Hays LT1 Tender...
UNUSED FUTURE BOBCAT-E SERIES EXCAVATOR (A60432)
UNUSED FUTURE...
1992 DFI PULL SPREADER (A57192)
1992 DFI PULL...
