Air loss in alloy rims?
   / Air loss in alloy rims? #21
I have a 2009 GMC Sierra with just over 100k miles. Back around September 2014 I had a new set of Cooper AT3 Tires installed. Now this last fall we've been losing air on 2 of the tires.
Anyone else experience this problem? Easy fixes?
Had a 2003 Tahoe Z71 that had aluminum wheels. New tires at 123,000 and one air leak a year later on one wheel. It was a bead leak, simply broke the bead, cleaned, remounted and all was good.
   / Air loss in alloy rims? #22
I have had slow leakers on about every combination of tire brand/rim imaginable. If there is nothing in the tire (nail/screw) it is ALWAYS the bead or valve stem.
Even a slow leak will show up in a dunk test or a soap and water test. If they cannot prove its coming out of the rim, dont buy the BS. Make them clean the rim and use a new valve stem. If it has TPMS its not likely that a tire shop will be changing that. But at least have them clean the rim. I bet that solves the issue
   / Air loss in alloy rims? #23
I worked at Kal Tire in high school till I graduated and fixed many bead leaks. Lots of the time it's about patience in finding them. We would leave the tire in the dunk tank for five minutes or so then come back and watch closely. Sometimes it was only an air bubble the size of a ball point pen tip every 30 seconds or so. One thing we also saw LOTS with the aluminum rims was cracking around the bead area and inside of the rim. The bead edge would wear so thin that it would actually break right off. The inside of the rim as well would get so thin it would crack and sometimes even a large hole would punch out. That being said these were oilfield and logging trucks that drove hundreds of kilometres in mud and sloppy gravel roads so there is non stop abrasive in the rims and as the wheel turns the calliper would push it around the rim.
   / Air loss in alloy rims? #24
Like 5030 said, on any ally rim there can be some minor amount of crud build up on the bead...Quads to trucks--all the same...A little wire brushing and a skim coat of sealant usually fixes it.
Agreed.. the bead area can erode and leak, and yeah.. there is sealer for it.
   / Air loss in alloy rims? #25
I can't say for sure what is causing your problem but I had a slow leak with a tire/rim on a 99 Yukon. After trying a few of the fixes suggested in previous posts I removed the tire from the rim, scuffed up the inside of the rim and painted it. No more leak. Apparently there was a porous area or a crack that the paint sealed however I never felt safe with that rim on the ground.
I worked at a service station when I was in my late teens. I fixed many leaks by breaking the tire down and cleaning the area where the bead seats. I've never seen a tech bother to clean that area when I had a new set of tires installed.
If you want to attempt it yourself take the rim off and break the bead on one side. Push the tire down to give you access to the wheel and go around it slowly cleaning the accumulated gunk. I like to apply WD-40 to the rim using a small rag. Let it soak a few minutes. Be careful to not get it on the tire or inside the rim. Use soapy water if you prefer but try to keep whatever you use from getting inside the tire.. Then apply a generous amount of elbow grease. Be sure to remove all the WD-40. Once clean and oil free, apply sealer if you want then reinflate the tire fully. Then let the air out and repeat the procedure on the opposite side of the wheel.
You can also try replacing the valve in the stem. The tech sometimes damages them when reinstalling.
   / Air loss in alloy rims? #26
I think you should find a new place to get tires. Where I go, its SOP to run a wire wheel around where the bead seats once the old tire is off. Takes them just a few seconds with it still clamped on the changer and rotating.
Also SOP to install new valve stems
   / Air loss in alloy rims? #27
I mount my own tires and on the older alloy wheels I take a 4 1/2" grinder with a cupped wire brush to the bead area. Before I started doing this they would always have slow leaks. If I change the valve stems I also clean up the area. If that doesn't work then I'll use some beat sealant.
   / Air loss in alloy rims? #28
Just had mine done. Amazing how much crud was there.
Kawasaki Mule 2510 4X4 Utility Vehicle (A55853)
Kawasaki Mule 2510...
2005 Honda Accord LX Sedan (A55853)
2005 Honda Accord...
2013 Ford F-250 Ext. Cab Pickup Truck (A51692)
2013 Ford F-250...
2017 Ford Explorer AWD SUV (A53424)
2017 Ford Explorer...
John Deere 7410 (A53317)
John Deere 7410...
2016 KBH Fertilizer Tender Trailer - Isuzu Diesel, Hydraulic System, Rear Discharge (A57024)
2016 KBH...
