Alarm oil pressure transmission renault 540 rx ares,
   / Alarm oil pressure transmission renault 540 rx ares, #1
leboisclairet
Renault 540 rx ares
Hello everyone,
I am new here and I hope you can help me with the following problem
A few days ago, immediately AFTER switching on the PTO to drive a disc mower (rear) our renault 540 rx ares gave up.
What no longer works:
- driving forwards or backwards
- PTO no longer works
- power steering does not work
what do we have:
- oil pressure transmission alarm
- sporadic oil temperature transmission alarm (also when cold)
- frequent undervoltage battery alarm
what did go shortly after the incident:
- driving half a metre forward or backward, the more gas you gave, the slower it drove, until it stopped (we're talking about 1 km/h)
- the lifting arms still went up and down, now it doesn't.
what have we checked:
-oil level is perfect (and clean oil)
- oil filters have been checked , both look good (not collapsed and not saturated)
- fuses checked , all ok.
Now I have no experience with Renault (I do have experience with Fiat tractors) so I wanted to ask your opinion here what could be the cause of this before I start tinkering.
what could be the cause here?
the transmission hydraulic pump? the clutch? other possibilities?
Thanks in advance for your opinions!
Kind regards
Tim
   / Alarm oil pressure transmission renault 540 rx ares, #2
Hello everyone,
what do we have:
Kind regards
Tim
I believe you may have answered your own questions towards the end there.
Sorry I don't know your particular model very well but is there a way to check hydraulic pressure at a test port somewhere on that machine?
Kubota L4630 (A50123)
2018 FREIGHTLINER CASCADIA TANDEM AXLE DAY CAB (A53426)
2018 FREIGHTLINER...
2001 TOYOTA TUNDRA SRS EXT CAB TRUCK (A51247)
2001 TOYOTA TUNDRA...
2013 Mitsubishi Fuso FEC72W 18ft Dovetail Flatbed Truck (A51691)
2013 Mitsubishi...
UNUSED JCT HYD TRENCHER (A51248)
UNUSED JCT HYD...
2023 Yamaha R Max XTR  (A52384)
2023 Yamaha R Max...
