allis chalmers B12 starter wireing
   / allis chalmers B12 starter wireing #1
rustytinman
houghton lake mi
allsion challmers
i tore apart my tractor to re paint now i do not rember how it went or what went were there is a on/off switch, push button start ,selonid, 2 little lugs 4 small wire ? any help would b great thank you!!!! :(
   / allis chalmers B12 starter wireing #2
I might be able to help you I have a B12. Is yours powered by a 16 hp
Briggs And Stratton?
its briggs & stranton 12 hp i just need to no where the 2 wires go from the selinod got it 2 cranking that info would be great thank u
   / allis chalmers B12 starter wireing #4
I don't mean to make this long and painfull,but are the wires still attached to the soleniod? I will check my manual today for the diagram.
yes 2 there is 3 posts on the silnoid don't know if it is really a selnoid its a black box with 3 posts but there were only wires on the 1st 2 they r short like they can only go to starter or battrey i would think thanks 4 any info!!!!!!
   / allis chalmers B12 starter wireing #6
I tried to send you a message With a wiring diagram attached but i have had no luck. If you send me a private message. I think I can reply with the attached diagram.
did u get my email any ways yes it is avoltage regulator 1st post has nothing on it 2nd says gen 3rd says bat any info would be great do'nt c how to im u
   / allis chalmers B12 starter wireing #8
Well Partner the older I get the more confused i get about these computors. However time is not all lost . My son will post this next week when i give him the schematic. Next time i'm going to saddle up the old mule and deliver it to you in person.
if u got my email it should go through that. i'm no puter wiz either i have never even used im i just use email 4 everything .but that will be just fine .can u also tell me what fluid they reccomend to put in the gear boxes ? thank for all your help
UNVERFERTH 330 - 22-INCH EXTENTSION TUBE FOR BASE AND WING ASSEMBLY FOR RIPPER (A55301)
UNVERFERTH 330 -...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A53421)
2025 Kivel 48in...
20pc 4ft. x 3ft. Yellow Metal Diamond Plate (A55758)
20pc 4ft. x 3ft...
2006 STERLING L7500 DUMP TRUCK (A51406)
2006 STERLING...
2016 Ford F-550 Palfinger PSC3216 4,000LB 2 Ton Crane Service Truck (A51692)
2016 Ford F-550...
2013 FORD F-450XL SUPER DUTY BUCKET TRUCK (A51406)
2013 FORD F-450XL...
