Allmand TLB
/ Allmand TLB #1
Dwellonroof
Batavia, Ohio
John Deere 3046r
Anyone here with an Allmand 425 or 535 backhoe I'm looking for the Eaton number off the gear pump and maybe a picture or two.
I'm thinking someone installed the wrong pump in mine.
/ Allmand TLB #2
I'll check my 535 tomrw I think it's an Eaton 72400
/ Allmand TLB #4
It was frozen solid today ill try tmrw
/ Allmand TLB #6
Cant really get in there for better shots
/ Allmand TLB
That looks like it I'll order a seal kit and see if that helps my weak loader/hoe.
/ Allmand TLB #8
Theres mesh screens that at the tank bottom that might have debris
/ Allmand TLB
I drained the fluid and removed both strainers and installed new filters and replaced with new fluid.
It drives back and forth great. The steering works great but loader and backhoe work but are weak.
/ Allmand TLB #10
check that the relief valve isnt stuck. I dont know how to do that but it is one of the troubleshooting steps in the operaters manual
/ Allmand TLB
The seal kit is to arrive tomorrow and hopefully it has the Orings for the load sense valve in it.
/ Allmand TLB #12
Keep me posted please
/ Allmand TLB #14
When u pull that out is there any check balls or springs that come out with it.
/ Allmand TLB
It came out as one piece but I can see inside it has what looks like a valve of some sort.
I found the oring seal kit for it but also found a complete valve so new valve is on it's way.
/ Allmand TLB #16
Please post the part number for the seal kit. I might do mine
/ Allmand TLB
9900205-000 seal kit for the pump
Eaton 202914-921 SICV Accessories Seal kit
02-199283 Priority Flow Cartridge Valve
/ Allmand TLB
I installed the new parts but the loader and hoe are still weak so I installed the gauge at the loader and only getting about 1200 psi, I'm thinking it's the rear wear plate that is not part of the kit and maybe not obtainable. I have sent out an email to Applied to get more info.
/ Allmand TLB #20
Sorry to hear that hope you get it working again.
