allowable weight on a gooseneck?
   / allowable weight on a gooseneck? #11
Definitely legal. Been stopped by dot numerous times and they never unhook anything. Their major concerns are that you are not over tire, axle, or registered weights.
Make sure your truck is registered high enough for the tongue weight. I got an overweight ticket years ago for being over registered weight on my pickup due to tongue weight from a gooseneck. I have seen 3/4 ton trucks with registered weights of 8000lbs. The trucks probably weigh 7000 empty.
As others have said, yes you are legal.
As others pointed out with truck rear GAWR as well as tire rateings. if your GN does not have a load shareing axle setup
then its possible to over load one of the axles if your load is poorly placed on the trailer. (such as in livestock or other enclosed trailers that may have torsion axles)
Now that is interesting. Although my data pool is small, It seems that gn horse trailer blowouts tend to be the rear trailer wheel. Also a lot of horse gn trailers are a bit high nose which tilts it back a bit and if they have the torsion axles, overloads the rear axle.
   / allowable weight on a gooseneck? #13
Might be dependent on your state/area of operation, etc., but if you are registered other than combination all bets may be off. In other words, if you have your tow vehicle registered to cover the GCVW and are legal on the tires/axles they you should be fine. If you have say a 10k plate on the trailer, DOT can legally request that you drop your trailer to weigh the trailer axle and tongue weight.
I am not saying it is going to happen all that often but it did happen to my friend in Berks County, PA a number of years ago. He paid a fine plus had to go register his truck in combination before he could move his trailer load of hay.
   / allowable weight on a gooseneck? #14
Ken: Trailer Manufactures have lattitude as the the GVWR of the trailer, your Manufacture took a conservitive approach and badged the trailer at 14k. Check the weight capacity that is stamped on the tire, should be at least 3,500 pounds. You may want to contact the manufacture and ask if they will generate another plate. Maybe they will and maybe they will not.
From a DOT perspective it is really just a technicality and not a true safety issue as long as everything else is in spec with the tow vehicle weight wise. Over weight tires big problem.
I upgraded my tires to 4k, still have the same GVWR but when loaded 15-16k with 40% of the weight on the gooseneck the tires do not look loaded or squish a bit. Tires that look overloaded are quickly going to get the attention of an inspecting officer who then is going to start asking questions and wanting to see documents.
   / allowable weight on a gooseneck? #15
Also check your tire pressures, they can give you a ticket for under-inflated tires, and are more likely to do so if they also find another other problem and want to get the $$$$ ticket up.
   / allowable weight on a gooseneck? #16
Goose neck trailers can be adjusted to the proper height. All trailers should be towed level. Most people don't take the time to make adjustments.
   / allowable weight on a gooseneck? #17
Most horse trailers with a bunk above the neck cannot be adjusted to level. Even if you could, the truck wouldn't have bedsides or a tailgate after the first dip in the road or driveway approach.
^^^ that's the issue we have, I have a sharp breakover starting down our driveway. Very, very little clearance and the trailer is a bit high in the front.
IMO they should make them with a bit more clearance.
   / allowable weight on a gooseneck? #19
Some are better than others. I had a Stidham at one time that was custom built for the NFR show fiveteen years ago. The roof was taller like a thoroughbred, and the floor of the bunk was raised up the same amount. It made a normal size bunk with better truck bed clearance.
I've seen guys with toybox trailers put a lift kit on them to get better bed clearance. That would work for a horse trailer if you had a ramp gate.
   / allowable weight on a gooseneck? #20
I guess I am lucky then. I have about 11 inches of clearance. image-3585950482.jpg The bunk on mine is a little low. Wish it was about 6-12 inches higher, but there is no problems. The total height including the AC unit on the top is under 11 feet. As I look at other trailers at this horse show they are a lot lower to the bed than mine is. That's my 2001 F-250 4x4 with an Elite trailer. Two horse straight with one horse slant. Most of the time we just set it up as a two box stalls. I can see problems if you raise a pickup up 8 plus inches.
2025 Swict 78in Bucket Skid Steer Attachment (A53421)
2025 Swict 78in...
Mini Excavator Rake (A53316)
Mini Excavator...
2018 Ford Fusion Hybrid Sedan (A55758)
2018 Ford Fusion...
2015 Ford Taurus AWD Sedan (A54815)
2015 Ford Taurus...
UNVERFERTH 330 - 19-INCH EXTENSION KIT FOR RIP-STRIP TOOLBAR PART # 63186G (A55301)
UNVERFERTH 330 -...
2004 INTERNATIONAL DURASTAR 4300 BOX TRUCK (A55745)
2004 INTERNATIONAL...
