Alternative for hydraulic hose?
   / Alternative for hydraulic hose? #21
The guys at Shaver told me that they had to go to the 1000 psi hose because of numerous complaints about the other style return hose.
There is only the right way and what you think is your way.
People people, just do what you want.
   / Alternative for hydraulic hose? #22
I have no doubt that Shaver had to upgrade the return hose due to customer's chronic inability to follow instructions and plumb the return as directed. I have seen, sold and set up several Shaver drivers that came from the factory with 200 PSI return hose, and am certain there are hundreds of them out there working sucessfully so equipped.
   / Alternative for hydraulic hose? #23
Bingo!! CYA, they don't want to get sued for somebodys stupidity. "Intelligence is limited, Stupidity in limitless." CJ
Hey Everyone,
Thanks so much for all of the help and advice! I learned a lot.
I didn't think I would have any trouble finding a return line locally but boy was I wrong. Nobody had a 1" return line in stock.
I need to pound posts tomorrow and Monday. I've got a few hundred to do.
Since I didn't have a lot of choice, I ended up going with this ribbed PVC suction line from Northern Tool. It may not last forever, don't even know if its rated for oil nor do I know how much PSI its rated for. But I figured a suction line would have to be fairly stout to keep from collapsing. I bought it, cut the ends off and inserted a 1" barbed by 3/4" pipe fitting into one end -- which screwed it the valve. The other end I stuck into the hydraulic fluid tank. I'm happy to report its working perfectly! I pounded a test post tonight before it got dark. Tomorrow I'll be hitting it hard (pun intended).
I'll let you know if the hose holds up. Maybe it will help someone else.
2019 GALYEAN EQUIPMENT CO. 150BBL STEEL (A58214)
2019 GALYEAN...
2020 INTERNATIONAL LT625 (A58214)
2020 INTERNATIONAL...
2018 Nissan Titan 4x4 Crew Cab Pickup Truck (A56858)
2018 Nissan Titan...
2006 Columbia Medical Transport Electric Utility Cart (A56857)
2006 Columbia...
72" General Purpose Skid Steer Bucket, S/N 103581 (A59076)
72" General...
Pig Statue (A57149)
Pig Statue (A57149)
