Alternator problems?
   / Alternator problems? #31
you should DO SO...
   / Alternator problems? #33
remember.. on a center 0 ammeter.
put alt/genny charge wire one one side of ammeter.. put other side of ammeter to battery or hot side of solenoid.
put ALL loads like lamps and ignition, etc, on the sid eof the ammeter with the alt/genny.
orient wires so that meter is deflecting positive when running.. and negative when ff with lamps on.
this gives you a net charge / discharge setup.
Put a GM 10SI one wire unit on and be done with it for anot $70
Chris
What worrries me is that the alternator connects to the control module, the alternator does have a voltage regulator built in.
   / Alternator problems? #35
new alternator but battery goes down quickly meaning hay baler operates at 10 %
normal speed
   / Alternator problems? #36
if the bat goes down.. alt ain't working...
UNUSED Tool Set (A53117)
UNUSED Tool Set...
MARATHON 20KW GENERATOR (A55745)
MARATHON 20KW...
2007 Heil Heavy Duty Aluminum Tank Trailer (A55314)
2007 Heil Heavy...
2019 Ford F-550 4x4 Terex LT40 40ft Insulated Bucket Truck (A55852)
2019 Ford F-550...
2024 Schulte 5026 Batwing Rotary Cutter (A55314)
2024 Schulte 5026...
1989 Miller Legend AEAD-200 LE Towable Welder Generator (A55851)
1989 Miller Legend...
