Volfandt
Veteran Member
I've seen many a crack and break in cast iron. Front axlw housings, broken TE30 and 8N 3PH's, engine blocks and fe DWV to name a few. Cracks are not limited to aluminum....
Temps can run as high as 100 degrees higher than the ambient outside temp in HST's so a cast aluminum HST would be more condusive to dissapateing heat than one made of cast iron.
Corrosion can and will wreak havoc in cast iron.
An aircraft will not be able to defeat gravity if it was constructed with cast iron and the cost's would be in the billions to keep them corrsion free if they could
Other materials in an aircraft are also routingly inspected for stress cracks, the steel landing gear rods and the composits used in framing come to mind...
The highest performance internal combustion engines in use today utilize much more cast aluminum than cast iron in the most stressful components.
Can't wrap my potato in iron paper
Volfandt
Volfandt
