An Old Goat Ranch in Texas
   / An Old Goat Ranch in Texas #501
Good to see that you are almost sealed in. Are you having the windows custom made for those odd angles?
Eddie
   / An Old Goat Ranch in Texas #502
Terry, I see you like your buildings like your like your ice chests. . . with white roofs.:D That'll sure help to keep things cooler.
It's been hitting over 100f in the shade real regular around here...that white roof and 14 foot peak on the ceilings makes a HECK of a difference...we are installing a vent fan that should be sweet when fall finally arrives...
Single pane of lexan? Will that be a problem for your overall R value?
Eddie
It is my opinion that "R'" values, like excitement and Cuban cigars, are vastly over-rated...
The design objective for the deadlights was to flood the Great Room with natural light each morning and evening....
The deadlights will have two layers of glazing with air in between...the r-value was not as big a consideration at the desire for the light...tho thermal gain via sunlight WAS considered....the August sunlight/shade survey I performed when I drew up the plan on Sketchup showed the deadlights that face the porch will be shaded from about 10 AM on, while the kitchen deadlights will begin to recieve direct sun at about 4:30...I have a retractable (motorized) solar screen planned for the kitchen windows...so far the survey is spot-on for predicting the shade times...
Overall the house is NOT designed to employ the latest "sealed house" technology...I feel strongly that the current crop of "sick houses" and moldy remediation nightmares are the fault of too little air movement in the structure in an attempt to wring every possible "R" out of it....my house is intentionally VERY loose...
I will pay a few more $$$ over the life of the structure in the form of BTU's rather than spend it up front in the form of "tight" technologies...
....the walls and roof are vented full length from ground to peak thru the "ribs" to allow passage of air outside the insulation envelope to keep moisture from collecting...
...passive cooling of the occupants is provided by a thicker slab coupled directly to the earth (vapor barrier without insulation) which so far has maintained an August average temperature of 80f, masonry flooring (stained concrete) rather than insulative wood or laminate allows the floor to act as a "thermal flywheel" moderating temperatures day and night...
...high ceilings throughout the house to allow warmer air to rise above occupants head level, (there is no attic...the roof line is the ceiling line), a "whole house" vent fan set at the peak can be used to eject hot air on extreme days or pull cool air in through the screened windows and doors during more clement periods, all rooms peaks are vented to allow passage of hot air to the vent fan...
....wall and ceiling cavities allow ample room for insulation (2x10 rafters and 2x6 walls) which will be good old fiberglass, the air infiltration barrier is planned on the inside of the insulated space to control drafts, rather than the classic "house wrap"....I WANT air to move thru the walls in a controlled fashion...
...AC will be provided by thru wall units to allow zoned cooling, heat will be added as needed by vent-free gas heaters provided in each bedroom, the bath and a gas / wood masonry stove in the Great Room...
...ceiling fans WILL NOT be used in the summer to provide airflow for cooling, this avoids mixing the stratified hot and cooler air and raising the average tempurature in the portion of the strata occupied by people, hot air rising to the peaks to be ejected from the space...during cool weather, ceiling fans WILL be used to prevent stratification and RAISING the average temperature in the occupied zone...
During the current heat of High Summer, the interior, tho uninsulated, is surprisingly cooler...
I'll let you know how the 20 year cost study works out...
T
   / An Old Goat Ranch in Texas #507
Darn! I would really like to see the results of that study, but doubt I'll still be around. :rolleyes:
   / An Old Goat Ranch in Texas #508
One of the best things I like about Texas is being able to build what you want on your land. I'm not in agreement with your thoughts on heating, cooling and airflow, but I love that you are doing it your way. I'll still be here in 20 years and look forward to the results of your study!!! :)
Eddie
Eddie
...oh the lack of Gummint oversight is one of the chiefest delights of "country living"...well....that and having an 800 foot driveway so you can pee off the porch without upsetting the Church Ladies...
....the only Gummint entity I have to answer to is the TDEQ, who insist that my sewage system be installed by a certified installer...outside of that, anything goes..but overall, I hold the Electrical and Plumbing codes in pretty high regard, since, as my old Chief Petty Officer used to say as he held up the Rules:
"....aight you Muggs...every line in this here book was written in somebodies blood, and we WILL treat it with all due respect..."
Stay cool...
T
T/A Utility Trailer (A56858)
T/A Utility...
2013 PETERBILT 389 (INOPERABLE) (A58214)
2013 PETERBILT 389...
POLY TOTE W/ WIRE CAGE (A58374)
POLY TOTE W/ WIRE...
2020 CATERPILLAR 299D3 SKID STEER (A52709)
2020 CATERPILLAR...
Bobcat T590 (A53317)
John Deere 6120M (A57148)
John Deere 6120M...
