Analog Multi-meter question,
   / Analog Multi-meter question, #11
B.W.D. This screw is to place the pointer to 0 when no voltage on meter. be careful go to far and messes up the setting stop.
On the ohms setting touch the leads together pointer should go to 0 on the scale then release pointer should return to full scale on the meter scale.
if not then adjust by again touching the leads together and one of the adjustment knobs should. then open and adjust to full scale reading each adjustment effects the other.
Depending on the grade of the components inside this should work.
ken
I really appreciate the refresher course on the use and set up for my Analog Meter.
Have had several situations here lately that have dictated the use of both my meters for testing.
Watching the sweep of the meter arm was very helpful while troubleshooting whether or not a TPS was good on a car I was working on. My digital would give readings of course, but with Auto Ranging, it always goes through several permutations before it settles on the final number. Therefore, it's kind of worthless to see if the TPS had a bad spot. With the analog, being able to see a nice smooth needle swing with no jumps or spikes, I was getting a more thorough picture of the parts correct function.
   / Analog Multi-meter question, #13
Just a side question for curiosity sake, but what is YOUR(this question is open to anyone) pitch/repair dollar amount?
I used to rebuild/repair all kinds of mechanics' air tools, and the usual thing in that business was to fix it if it could be done for half or less of the cost of a new one. Some customers asked for estimates first on anything, and I sure couldn't blame them for that. Some never asked for estimates, but if it was going to cost more than about a third the cost of a new one, I called them anyway to ask what they wanted to do.
   / Analog Multi-meter question, #14
Big Wave,
While you are at the electronics store getting a new meter pick up a 10 watt 1.0 ohm resistor.
Place it in series in the negative battery cable and then the car is powered by the resistor not your meter. (those internal meter fuses are usually a pain to replace and or find)
Attach the leads of your meter across the resistor to accurately measure the voltage drop to measure the draw. Using the low volts scale and the readings will be IE .030v would equal 30ma. hth
Steve
Big Wave,
Steve
Car Doc,
Thanks for the advice.
For a little clarification, for me, are you saying I should take the Resistor, solder some leads onto its ends, put some aligator clips on the ends of the leads, and then for proper use, clip alligators to (-) battery terminal and (-) battery cable?
Once this is done, take reading off of resistor, by touching both sides of resistor with meter leads?
I would be using this method as a means of determining Parasitic Battery Drain? That's what I'd gotten my old Analog Meter out to do in the first place. It has the 10 AMP, DC setting. My little DMM can only read to 200mA. Needless to say, it smoked the fuse in a heart beat.
   / Analog Multi-meter question, #16
Car Doc,
Big Wave,
You are understanding very well yes the alligator clips will make the connections easy and yes use the negative battery cable to test drain and yes just connect them across the resistor it protects your meter and gives an accurate reading, you are converting voltage drop into amperage.
You would be reading volts though and its directly relative to amps in that while reading a DVOM on low volts scale you are actually reading the mili amps, a digital meter works the best especially an auto range type like you have. Got any more questions I will answer the best I can have fun :)
Btw a +200ma draw is severe 50ma is about the max on a late model car w/multiple ECU's you may smoke the resister as well but it wont kill your meter that's the good part fwtw
Steve
Car Doc,
1994 Olds 98 Regency w/3.8, naturally aspirated.
Surely this qualifies as late model.
So if the 50mA thing is an average Parasitic Draw, then if I smoked my meters fuse, something's amiss.
I was having this random dead battery problem. Start fine for a week or two, then might have to jump it.
The battery was less then 2 months old. Just replaced the previous AC Delco that had been in it. Also, the alternator is less than 2 years old.
I found spot on internet that gave voltages for car battery at 100%, 75%, ... Anyway, 12.78 volts they called 100% charged. My battery would never read past their 50% value. With car running, I would read about 14.12 volts which seems to be on the good side of normal, and with all heavy load items going full blast, it still would read 13.8+
I thought that with the meter readings it was pointing to the battery, or now, I might say that the battery was part of the problem. I'm concerned then about the fuse blowing on my tester. That seems to indicate I still have to much draw, and that I'm going to be killing this battery off soon too.
Thoughts?
Thanks again
   / Analog Multi-meter question, #18
Big Wave,
Battery's cant be checked with a volt meter they need a actual load test to know for sure, GM alternators leave a lot to be desired imo I don't trust them as far as I can throw one and bargain parts store remans are the worst fwtw.
Right off I cant think of a common pattern failure on that car, ignition switches can be a source of trouble and are harder to diagnose than most electrical switches just because of their position in the car and the fact that's where a lot of your power goes thru the fuse boxes.
The first thing I do when I have a batt drain come in to my shop I load test the battery then I look for things that someone has added to the car then if there isnt anything or after I un-plug it and still have my drain I unhook the alternator at the big B+ terminal and see if it goes away thats the first thing. Alternators can drain w/o causing any other symptoms besides they stay warm long after the car is shut down and can still produce acceptable amounts of power as far as a simple meter voltage test.
Next is isolating which circuit is causing it, the way I do this is start unplugging things one at a time while watching my meter or test light, you also use the 12v test light in series with the neg batt cable for the rough measurement I stress "rough" it doesn't take much to light one up but it does help diagnose.
I use it first sometimes its easier to see when you are cramped under a dash and you can add longer leads to bring the light inside the car with you if necessary.
The light will dim when you get close to your problem when un-plugging things but after that its a meter measurement to determine if its acceptable or not. Its not an exact science using a test light fact it can throw ya off track so just use it as a tool to get close to where you need to be. Pull the trunk light bulb first thing also just because.
Keep in mind the door button for dome light can have a count down dimmer timer that will reset each time you open the door etc and even a seatbelt or door open light on the dash and cause a large draw right away and then dwindle down and the computers wake up each time the key is turned on and the body computer will wake up with the door opening and they take sometimes 20 minutes to go back asleap keep that in mind also dont get in a huge hurry. If I need to be in the fuse box under the dash I usually dis-able the dome light either by pulling the fuse for it or making a block that pushes the button while I have the door open. I am creative so it depends on the car how I do it.
If you have any more questions I will be happy to add ideas.
edit: I may add that when you un-plug the B+ at the alt also (with key off) pull the small wire also off it and check it for voltage at the wire not the alt, this will test to see if the PCM is powering the alt with the key off. It will be hot with key on normally and thats what turns the alt on when its working properly, it doesn't mean the alt is good though we are just checking the car itself.
Steve
Car Doc,
THANK YOU so much for the more likely places to look first.
So far, everything seems to be acting normal.
Can a load test for battery done with any accuracy with the battery in the car or should I pull it and let them bench test it?
Thanks again
   / Analog Multi-meter question, #20
You are welcome!
Yes you can test it in the car that's how I almost always do it I hardly ever even take the terminals off. Parts stores usually will test them for free since they are happy to sell battery's you can ask one of them.
Seeing the amount of spark when touching a terminal to a battery post gives some idea how much drain is present also a small amount is normal but if its enough to transfer any lead its probably too much fwtw.
Steve
2008 OVERLAND TANK KILL TRAILER (A52472)
2008 OVERLAND TANK...
NEW HOLLAND 706 30 INCH 3PT DIRT SCOOP (A55301)
NEW HOLLAND 706 30...
2012 CHEVROLET SILVERADO SINGLE CAB TRUCK (A51406)
2012 CHEVROLET...
NEW Work Saver Skid Steer/Sub Compact Grapple (A53473)
NEW Work Saver...
2018 Chevrolet Colorado 4x4 Ext. Cab Pickup Truck (A53422)
2018 Chevrolet...
