Anchor stuff for bolts in concrete...
   / Anchor stuff for bolts in concrete... #21
Back in the early seventies I was one of three people in my telephone company yard that was licensed to use the Hilti powder actuated hammer. Now in Texas you can buy one and the loads at any hardware store.
I still think there should be a licensing of some sort for their use. The reason is grabbing a hot load and holding the gun for lack of a better term just a little off plumb can send concrete and a very very hard nail out like a BB in a boxcar.
I carry a Remington on my truck with loads and nails along with studs. Probably the most unusual use I've found that ya'll might find interesting is attaching aluminum plate to steel where conventional methodology is inconvenient or undoable.
I built some cabinets into a fence line. We had brick columns and an angle iron lentil with brick betweem the columns. I wanted the cabinets to be water proof. So I made the top and back out of eighth inch aluminum broken to fit. Drilling and taping existing four by four by half inch angle iron to attach the aluminum plate was out of the question. So I got out the Remington. I drilled three sixteenths holes in the plate where I wanted to attach it to the lentil. Using short nails and washers designed for attaching to steel and a very hot load it was a done deal in a matter of minutes. BTW I learned it was very very very very very very important to predrill the aluminum plate. Even though the aluminum is soft attempting to go through it and into the steel didn't work worth a flip
   / Anchor stuff for bolts in concrete... #22
W harv,
Thanks for the warning. Sounds like the voice of experience.
I've always been careful with it, but now I'll be doubly so.
Perhaps I should go buy a couple more before they start doing background checks in order to purchase/w3tcompact/icons/wink.gif
   / Anchor stuff for bolts in concrete... #23
>>> You might also consider using what I use, a Remington 476 Powerhammer. About $20 at HD or Lowes, it uses 22 blanks to drive special nails into concrete, up to 3" long I believe. I used it to anchor an interior stud wall for an office I was building and they worked great. Many others have borrowed it and all have had positive results. Very easy to use.
You need to be careful with these tools. They're great for shooting nails into a concrete floor, but can do a lot of damage if used incorrectly. I remember a renovation job several years ago when someone used one to nail into a block wall. The nail went through the wall and hit someone on the other side.
You cannot believe what I have already gone through to mount this bending column. I have hot water heat in the floor and did not have an accurate drawing of "exactly" where the poly tubing was located. This would be impossible to draw due to the turns etc. of the tubing so...
I bought an infrared thermometer off eBay. It is super cool. Has a red laser light used to aim it. Wherever the laser spot hits, it reads the temperature and registers it on a digital display. Dang is that thing fun. Not only did it locate the tubing, I have also played with it lots. I have R38 blown in insulation in the attic of my shop building. When it was about 90 F outside I shot some temperature reading in the attic of the building (it was about 110 F), but the building itself ambient temperature was 78. Ah the value of insulation. Also have shot temps of the charcoal grill, the hens wandering around in the yard, the dog, etc. Great tool/toy!
DrDan
   / Anchor stuff for bolts in concrete... #25
DR DAN they are cool i have two one for work one for home just be carfull who you point it at the person may think they are targeted
have fun edt
   / Anchor stuff for bolts in concrete... #26
Another use for the IR thermometer is checking your electric for any hot spots.
Oh my god if I had gotten caught checking out the butt temps of the gals at work, I'd be up on charges for sure!
DrDan
   / Anchor stuff for bolts in concrete... #28
Just curious...Where does one find these infrared thermometers and what is the approximate cost? Tia.
Mike
   / Anchor stuff for bolts in concrete... #29
Here's one place, <A target="_blank" HREF=http://www.griotsgarage.com/catalog.jsp?&SKU=50399>Griots</A>. $100.
Mines a Raytek Mini Temp and I got it new off of eBay for $78 with the carrying case and the guy tossed in some other goodies.
DrDan
DOOSAN G25 GENERATOR (A53843)
DOOSAN G25...
2017 CATERPILLAR D6T LGP HI TRACK CRAWLER DOZER (A51246)
2017 CATERPILLAR...
1838 (A51248)
1838 (A51248)
PALLET OF SCAFFOLDING (APPROX. 16 PC) (A52706)
PALLET OF...
2015 MACK CXU613 (A53843)
2015 MACK CXU613...
SET OF (4) ALCOA 24.5 ALUMINUM RIMS (A53843)
SET OF (4) ALCOA...
