And now for the inside scoop on the 4720...
   / And now for the inside scoop on the 4720... #31
Some tidbits...
My dealer just got back from the briefing - and also said there will be 4 models - hp will range from 43 at the low end to 58 at the high end. (gross, not PTO) Same base engine in all four. Roughly same size chassis and same tire sizes. They expect selling prices to be "about the same, at least for the first year" and are expected to start shipping in mid-June. (He didn't sound overly convinced on that last point).
Tim
   / And now for the inside scoop on the 4720... #32
My spies tell me the large frame tractors will ship in June with the med frame to follow in Jan/Feb. The small frame is scheduled for next spring.
The large frame will have a 4 cylinder turbo charged Deere motor built in Mexico. Torque reserve will be up 30% over existing models. Nothing was announced for the mid frame but the rumor is a 3 cylinder turbo.
All frame sizes will have an aero hood with curved loader arms, load capacities will be up slightly and is easier to remove. Tire size is the same.
Operator platform will have some changes to make it more roomy and improve the operator view.
   / And now for the inside scoop on the 4720... #33
Are you sure the engine is made in the USA? I think you'll find that the new engines for the 4020 series are coming from Torreon Mexico not Dubuqe Iowa........
   / And now for the inside scoop on the 4720... #34
I've been given bad information before but that was from the regional manager at deere. He said they were going to use the same motor that they put in the skidsteers.
<font color="green"> He said they were going to use the same motor that they put in the skidsteers </font>
Same engine, COULD still come from another plant....
   / And now for the inside scoop on the 4720... #36
If the s-s are using the same engine as in the new tractors then they all are coming from Mexico. A couple of years ago Deere moved everything except the big 6 bangers down to Torreon. So in today's economy I'd doubt very much that even Deere is building the same motor in two places on the same continent.
   / And now for the inside scoop on the 4720... #37
Well - just checked on the Deere site to write down some part #'s for the 460 loader and various options in prep for trying to get my 4710.
The 460 is no longer on the Deere site under the "build" function - but the 400X is. /forums/images/graemlins/tongue.gif
No specs I could find, but there are several options listed I don't remember seeing under the 460 banner.
Toothbars for the 61" and 73" buckets ($289/$337)
"Skid Steer Carrier" (avail. 7/1/04 at $380)
There is also a 72" grapple bucket ($2,100) - in addition to the 4-in-1. I couldn't remember if that existed before or not.
It appears that there is only one HD 73" bucket now, one that includes the replaceable cutting edge. I think there used to be one with and one without, in addition to the regular bucket.
Sounds like the basic attachment design is still Deere's not standard skid-steer, hence the accessory.
Be nice to know what the specs are compared to the 460 when on a "10" series - since someone said the 400X is supposed to be backward compatible. Right now I might have the option to choose either for a 4710.
Tim
The new grease zerks alone would make me want the new one...
400X Loader
(For 4500-4700 and 4510-4710 Tractors
Specifications Per ASAE 301.3
Measured @ Pivot Pin:Lift Capacity 2368 Lbs. (1074 kg)
Lift Height 112.8 In. (2864 mm)
Boom Breakout 3506 Lbf. (15,600 N)
Dump Angle - 46 Degrees
Rollback Angle - 31 Degrees
Quick-Tatch Loading
Quick-Tatch Carrier
Mounting Frame
Hood Guard
Bucket Level Indicator
73 In.(1850 mm) Materials Bucket
460 Specs
Lift Capacity 1057 kg (2325 lb)
Lift Height 2843 mm (112 in.)
Boom Breakout 17182 N (3863 lb force)
Dump Angle 45°
Rollback Angle 30°
The new loader refernces ASAE Specs which means there could be a slightly differant yardstick being used...
BTW the new loader's name (400x) matches the new model #'s that are rumured. The 430/420 replacement would be 300x. and a 200x for the small chassis...
2016 FORD F250 XL SUPER DUTY EXTENDED CAB TRUCK (A51247)
2016 FORD F250 XL...
2018 Toro Workman GTX Electric Utility Cart (A51691)
2018 Toro Workman...
Case TR270 Skid Steer (A52384)
Case TR270 Skid...
2006 iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A51692)
2006 iDrive...
1995 Mazak VTC-16B Vertical Traveling Column Machining Center (A51691)
1995 Mazak VTC-16B...
2008 KALMER 4X2 SPOTTER TRUCK (A51247)
2008 KALMER 4X2...
