I tend to believe that.cp1969 said:The manufacturer's recommended filter will catch anything worth catching.
crbr said:Magnet in the filter of the Allison Transmission. It collects what the filter doesn't. I always make sure I have the magnet with every change.
Each to their own.
DieselPower said:There usually is a .002" clearance on parts like bearing's. However, under load these clearances can shrink quite a bit. The crank bearing is a good example of that. Under full load the clearance can shrink well under .001". There are other parts like lifters, rockers, gears, chains... that have no clearance at all save a hydrodynamic layer of oil.
Hey Nighttrain, didya ever try to clean the metallic crud off those magnets. once its there it isn't going anywhere.Nightrain1 said:What happens when you get more metal around the magnet then it can hold? I was suprised from my drag racing days, just how much metal these magnets attracted. They would build a mound of metal pretty quick. I was afraid eventually it would let a part of the collected metal all go at once. I was a big fan of magnets on the oil pan till a guru told me the launch would sometimes break clumps away to circulate through the motor all at once.
