annular cutters: a better way to drill big holes in thick steel
   / annular cutters: a better way to drill big holes in thick steel #51
Thomas,
Champion's head office is in upstate NY somewhere (Rockville I believe). I'll email my contact there tomorrow and find out a dealer for you. What town are you in/near?
Regards,
Mark
   / annular cutters: a better way to drill big holes in thick steel #52
Thomas,
I was able to dig up this distributor, not sure how close they are to you..
Cook Iron
Rochester, NY
585-454-5840
Regards,
Mark
Found the arbor on Hougen's website.
I just checked out your link and see the Hougen arbor for 1/2" Jacobs chucks
that you mentioned. What did it cost you?
Back when I started this thread, I wanted only a Morse Taper arbor, but I can
see that an arbor for a portable drill can be very handy. I did not see one
when I was looking and when I bought my Champion bits. With a large
hand drill, you can go very slow, and really flood the area (if outside) with
coolant. My geared head 1/2" hand drill is a wrist-buster.
If a Jacobs chuck arbor costs anywhere near what I paid for my MT3 arbor,
I would consider getting one.
I just completed a bunch more 3/4-7/8" holes in 1/2" plate. Sweet.
   / annular cutters: a better way to drill big holes in thick steel #54
MarkP2321 said:
Thomas,
Cook Iron
Rochester, NY
585-454-5840
Regards,
Mark
Hi Mark,
I'm just west of there, near Brockport, so that's just great!
Thanks tons!
Thomas
No matter where you go; there you are...
   / annular cutters: a better way to drill big holes in thick steel #55
For you non-professional steel fabricators out there, here is the latest
method I use for drilling holes between 1/2" and 1 1/16" in steel plate,
up to 5/8" thick.
A lot has been written on TBN over the years about holes, but this is a
surprisingly economical way to go. I expected to see more on annular
cutters on MachineBuildersNet, but there is very little there. So here
I post.
First, a little history. I rarely drilled any big holes in thick steel until I
made my CADDigger back in the mid 90s. Back then, I had an O/A cutting
torch, but I was not very effective at cutting holes accurately enough
for my purposes. Some of the holes required were as big as 2" in 1/2"
A36 steel plate. I tried bi-metal holes saws, but it was very slow and
my Delta 16" drill press really complained. And, at 240RPM, it was WAY too
fast. I also had some of those cheapo Silver & Deming reduced-shank
twist drills for the 1" and smaller holes. I got a set from HF tools for about
$25, but they chipped easily, even in mild steel.
I also paid folks I know with milling machines to use end-cutters. I have also
paid a guy with a punch press $1/hole to do some 1-inchers in 1/2 plate.
They were OK, but inconvenient, and there was some distortion of the plate.
I upgraded my drill press to the biggest and slowest one I could find that
was not a geared-head unit. This is the 20-inch DP from HF, which is about
325#, and much sturdier than my old Delta. At 180RPM, it was still too
fast for some of these bits, however. I also moved up to Morse Taper 3
bits, which the new press supported. The bits in the photo are very nice
US-made units with MT-3 shanks that go right into the DP's quill. Much
nicer.....for at least the holes up to 1". Better US-made twist drills all worked
better than the Chinese S&D units, too. The larger bi-metal hole saws were
still not a very good solution.
I now use my plasma cutter and templates or a circle guide for holes
bigger than 1 1/16" diameter, and use weld-in DOM tubing to make up for
sloppy holes. I still need to drill anything smaller than that.
Enter annular cutters. Those familiar with magnetic drill presses have
probably seen these, and these DPs can be purchased for as little as
$500 now, less the cutters. I used a mag drill back in the mid 70s when I
was a technician in a lab, but it was many thousands of dollars. I now have
a way to use annular cutters in my drill press.
I do agree with the point you made here "annular cutters are more effective" for the kind of work you mentioned above, i dont know from where you tried to buy those, according to you i fond those are very costly but there is a place called "Mutualscrew and supply" where you can buy them by spending some Descent amount of money. It is the company which will deliver all kinds of Quality hardware tools for bearable cost. I hope this source will be Helpful for you.
i dont know from where you tried to buy those...
As stated, I bought mine on eBay. A quick check shows that there are still hundreds of
listings, and you can buy many brands of annular cutters for under $20 each, new, shipped.
You can get even better deals on sets. Much less than going to a tool company like Multiscrew.
   / annular cutters: a better way to drill big holes in thick steel #58
I'm not sure if this has been answered or asked but what is the ideal speed of these cutters (say in the 1 inch range)? My drill press will only go down to about 250-300 rpms.
thanks,
dave
See post #13 above. A basic mag drill has only one speed and runs these annular cutters at about
350 RPM (e.g. SteelMax D1). Any DP should be able to run them with the right arbor. I keep
mine at the lowest speed I have (180RPM).
   / annular cutters: a better way to drill big holes in thick steel #60
Thanks dfkrug
JOHN DEERE Z920M LOT NUMBER 238 (A53084)
JOHN DEERE Z920M...
2012 DODGE DURANGO SUV (A52576)
2012 DODGE DURANGO...
2018 Bobcat T-450 (A51573)
2018 Bobcat T-450...
2019 BIG TEX GOOSENECK  TRI AXLE 34FT 2 CAR HAULER (A52576)
2019 BIG TEX...
2015 Clarke Power Gen RC60D 47kW Towable Diesel Generator (A50324)
2015 Clarke Power...
91013 (A48082)
91013 (A48082)
