Another 2305 newbie
   / Another 2305 newbie #21
Below are two different pictures. The top one show how I connected chains metal scrap (3/4" hole to accepts the top link pin (you will need a new top pin as opposed to the standard one) which holds the top link, and adjustable slotted metal slits towards the brush hog, so the chain can be adjusted). The chains are fasten to the brush cutter. Now, all I have to do is connect the bush hog, adjust the chains where I want the front edge to rest and take off, see the bottom picture below. In this set up, I can effectively change the position of the ride height of my bush hog. The dealer, assuming he/she has been selling small implements for sometime knows you can order/buy chains like this to allow position control and "use to be" standard on smaller bush hogs like the one shown above.
Not sure if you mentioned this before, but you will most likely want something on the front for counter weight, because the nose getting light. /forums/images/graemlins/grin.gif
   / Another 2305 newbie #22
Thanks for your help. I purchased five of the hang on weights too. Everything I've read about this tractor is great, I hope I bought the right one, looked real hard at the 2520 but it was 4k more.
   / Another 2305 newbie #25
Welcome and congrats on your tractor... phenominal machines /forums/images/graemlins/cool.gif
   / Another 2305 newbie #26
Stopped by the dealer and saw it all assembled this morning. Sure looks sweet . I can hardly wait to try it out. Hope the weather cooperates...
   / Another 2305 newbie #29
The wait is the most difficult part... Thankfully when my tractor was ordered it was my busy work season so I had no time to think about my tractor /forums/images/graemlins/grin.gif...
   / Another 2305 newbie #30
13hp Honda 7500 Watt Generator (A57454)
13hp Honda 7500...
12FT X 20FT STEEL CARPORT (A58214)
12FT X 20FT STEEL...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
Ford F450 Bucket Truck with Altec AT200A Boom (A56435)
Ford F450 Bucket...
2016 Doyle 10T Tender (A56436)
2016 Doyle 10T...
2015 UTILITY VS2RA 48FT REEFER TRAILER (A59575)
2015 UTILITY VS2RA...
