Another newbie looking for advice, JD or Kubota
   / Another newbie looking for advice, JD or Kubota #11
You might consider a heavier cabbed tractor for your terrain gives you additional weight & all weather capability. Especially since you already have a small tractor.
Cab also gets you a passenger seat.
I had decided that a 5105 spec wise was the one until I drove it & was too light on slopes.
I ended up with a 10,000 lb lifting & pulling monster. Size wise is just right for 32 sloped acres.
   / Another newbie looking for advice, JD or Kubota #12
Hi newbie, me too....
I have same questions as you. For the last three painful weeks I have compared about 50 tractor combos and chose the 5102 with 522 loader. As a matter of fact I just left dealer 20 minutes ago and gave them a check... Problem is the price is 21,000 for a 2 wheel drive.
what happened ? you got a 5105 MFWD for 23?
I think I need to find another dealer...
I only added telescopic links and armrests.. what gives.. ?
Can anyone suggest a dealer in Texas?
Thanks in advance
Yeah Barry, I'd love to have a big cabbed, turbo charged, air conditioned beast if I had the bucks! Maybe someday. But right now I'm trying to get as much tractor as I can afford that will get the job done. I'm leaning real hard toward the 5205 deal now.
A lot depends on how much its going to cost to get the property stumped out and leveled to the point I can actually start the plowing & planting. I'm waiting on the timber cutters to finish up and see how much cash I wind up with after all the bark settles.
   / Another newbie looking for advice, JD or Kubota #14
I don't know the specs on those particular models of JD, but the 5205 looks an awful lot like the 5105. You might not be getting much more tractor for your extra $1,000. A 6 hp increase might look good on paper, but it really doesn't look like you are getting any more tractor. They both weigh the same, and it looks like they lift the same weight at the three point hitch (not sure about that though). From what I can see on John Deere’s website, you aren’t going to get much, if any, more work out of the 5205 then the 5105.
I would be more inclined to stick with the 5105 or move to a 5303 or a 5320. Not long ago, I was looking at a M4900. After carefully considering everything I needed the tractor to do, I thought I would be right at the limit of the tractor’s capabilities. I didn’t want to outgrow another tractor in a couple years, so I bit the bullet and moved to a M6800.
The M5700 is essentially the same tractor as the M4900 (much like the 5105 and the 5205). The M5700 costs about $1,000 more then the M4900 and has more horsepower, but in reality it wouldn’t do any more work then the M4900.
It is helpful to write down what your immediate plans and future plans are for the tractor. The more detail you can provide the better. Once you know where you are going, you can start looking at the equipment you need. The work and the equipment you are going to use will really decide which sized tractor is best for you.
   / Another newbie looking for advice, JD or Kubota #15
I hear you! Last thing on my list was buying a new tractor without a ROI in sight /forums/images/graemlins/confused.gif
Get a 3rd hyd function on the front for a grapple - saves climbing on & off, chaining debris to the bucket. Staying with MFWD gets traction and 4 wheel braking on those slopes /forums/images/graemlins/tongue.gif
I paid $26.5K from local dealer for this one in pix last year.
JD wanted an extra $20K for a green one. I bought a Gator from him last month & he said "JD makes the best tractors" I agreed - especially when I could get a red one & save $20K!! /forums/images/graemlins/cool.gif /forums/images/graemlins/cool.gif /forums/images/graemlins/cool.gif
Zetor was the manufacturer of JD 2200 thru 2840 series utility class tractors in S American markets. Zetor p/n's are still in the JD database.
In any case, picking a dealer is a key part of the purchase. Plan out initial tasks + attachments AND going out 5 years. Trading prematurely might leave cash on the table.
Trust your seat time feedback. I just felt that the 5105 would leave me running around with daylight showing under the rear tires too much of the time /forums/images/graemlins/wink.gif /forums/images/graemlins/wink.gif /forums/images/graemlins/wink.gif
The more I look the more confused I get. I read here on TBN that the JD 5105 and the 5205 lowest operating speed is something like 1.8 mph and that this is too fast for tilling under some conditions. Has anyone with one of these machines experienced this problem? What conditions would require slower speeds for tilling?
What about the comparable Kubota's? I have not read of any speed issues with them.
Rockyridge- YMMVSYDFD?? Translation?
   / Another newbie looking for advice, JD or Kubota #18
If you have a Case dealer nearby, you should look at the JX75. You get a heavy machine (6,000 lbs.), bigger motor and 12 speed shuttle for not much more money than the 5205.
Chevrolet Metal Tailgate Art (A55853)
Chevrolet Metal...
2021 Ford F-150 4x4 Ext. Cab Pickup Truck (A55852)
2021 Ford F-150...
2023 54' Hooklift Dumpster 20 Cubic Yard (A53422)
2023 54' Hooklift...
WEILER S350 SKIDDER (A52707)
WEILER S350...
2004 Jeep Liberty Limited SUV (A54815)
2004 Jeep Liberty...
