Another newbie - which tractor
/ Another newbie - which tractor #1
deanojonesy
Hey everyone,
Here's the story:-
Bought 10acres, mostly cleared, slopping land - traction OK not muddy.
What I want to do with the tractor in order or priority:-
Slashing approx 5acres.
FEL work building kids motorcross track small jumps/corners/etc, general garden landscaping, driveways etc.
Some small amount of fencing.
Some Questions:-
1. What size hp would you recommend?
2. 2wd or 4wd? Little concerned about the slopping land and if 4wd would be any benifit or just make sure I get a wide wheel base 2wd? Also does the 4wd work better for FEL work?
3. General FEL with Bucket or 4in1 Bucket (not sure if thats what it is called in other countries?)
4. What tranmission? Have heard that if you are doing a bit of FEL work then to get Shuttle shift or similar as you go back and forward alot and dont have to stop to change gears? Do older tractors have Shuttle shift or is ot only a new feature?
5. New 30hp or Second Hand 40hp+? Can get a NEW Agricat (Foton) 30hp 4WD with 4in1 bucket & 4ft slasher (would prob get 5ft upgrade) shuttle shift 5yr part labour warranty for $18,500 OR Second Hand Something like Massey Ferguson 40 2WD standard FEL bucket for $15,000 OR SAME Corsaro 70 4WD standard FEL bucket for $14,500 OR International 484 2WD 2800hrs standard FEL bucket for $13,750?
Thanks for your Help everyone.
Jonesy
from Australia
/ Another newbie - which tractor #2
Hey everyone,
Here's the story:-
Some Questions:-
Jonesy
from Australia
I have a 2008 Mahindra 5525 (54 hp engine, 45 hp pto, 2WD, power steering, partial constant mesh tranny, 8F/2R). It's a heavy, simple tractor with a basic partially synchronized tranny. Paid about $17.5K for it. Use it on my 10-acres of flat pasture. Have 5 acres this year in oat hay (plant in Oct, bale it in May).
It takes a little learning to use the FEL efficiently with that simple gear tranny. If you're in a hurry, shuttle shift or hydrostatic trannies might be a better choice.
My guess is that Mahindra has a pretty large presence in the tractor market Down Under.
/ Another newbie - which tractor #3
10ac and 20-30ish hp tractors are a good match... 4wd and sloping land is a good match.. especially if there is a loader involved. A box blade will be a usefull tool to help make that track as well. that and a 5' rough mower as long as you go 25hp+
soundguy
/ Another newbie - which tractor #4
Listen to Soundguy on tractor size and don't fall prey to worshipers of excessive horsepower. With regard to transmission, if you are doing a lot of FEL work then HST is nice. 4n1 buckets are expensive and over rated unless you are a contractor needing max flexibility in a trailerable all in one tractor. For the price of a 4n1 you can get a standard bucket, grapple and box blade which will give you three tools that do any job better than a 4n1.
/ Another newbie - which tractor #5
After having 2 SAME's that would be my first choice and the 484 my second.
/ Another newbie - which tractor #6
Don't get me wrong.. I love excess hp.. but for specific jobs.. I've got a 95hp machine in my barn to pull a 15' mower.. but then.. I like to mow my 13ac in 3 hours :)
for regular chores.. 30 and 40 hp machines do the work..
soundguy
/ Another newbie - which tractor #7
soundguy
I would say that 95hp is not excessive for a 15ft batwing.
/ Another newbie - which tractor #8
not excessive for the batwing.. but the 95hp tractor and batwing mower may be excessive for 13ac :) but I like it.. and the quick mow time free's me up to do other things.
soundguy
/ Another newbie - which tractor #9
Hi Jonesy-
I've been researching tractors too, and agree with what's been said above about HP, 4wd, and trans type.
As to new or used, I'm definitely going to buy used. I have 5 acres of sloping land and I'm going to grade an orchard and other paths, maybe dig a septic and maybe even a foundation, and also snow clearing.. But I will NEVER put the kind of hours on the machine that a pro farmer or contractor will. I can get a machine with 500-1000 hours on it that's in good shape, and use it for twenty years and not wear it out. Sounds like you are in the same boat. So why pay for a 0 hour machine, unless you just want to?
You asked, "buy new lower hp or used higher hp?" I'd say get a good used at the minimum hp you are willing to live with. Spend the rest of the money on attachments. As you know, the tractor is useless without them, and the more you have the more you can do. Do you want the biggest, newest tractor you can get for bragging rights, or do you want the most capability for your money? I want the latter. My land is off the main highway and no one will be able to see my tractor anyway, except my neighbor, and he's already jealous of my truck so I don't need to aggravate the situation with a shiny orange. I'll get something faded like his so he won't think I'm uppity.
Just my 3-1/2 cents.
JG
/ Another newbie - which tractor #10
Soundguy and Island have given you good advice. 30 - 40 hp, HST tranny, grapple, 4WD, 6 foot bush hog. There are many many good brands out there. Dealer is just as important. The Fotons might require more wrench turning on your own. Some like the chinese tractors. Others hate them. I would suggest you take your time and look at as many tractors (both new and used) before pulling the trigger. I'd also say to get a toothbar.
/ Another newbie - which tractor #11
I would say 40 to 50hp. Along with HP, you need to consider how heavy your tractor is. A light tractor with more hp wil do less actual work that a 'beefier' tractor with less hp. In other words, a 40-50 hp compact tractor will not be able to do the work of a 30-40 hp utility tractor. Secondly, match your implements (and your workload) to your tractor. And remember, cheaper is not always better or even good enough. You can't do with a light duty peice of equipment what you can with a heavy duty one. If you want to clear the land, you will need the 'bigger' tractor. If you are just maintaining and cleaning up, then you can probably get away with the smaller/lighter tractor. I am a believer in 4wd. Especially with the FEL. True, I have gotten my 4wd tractors stuck more than I have my 2wd tractors. A lot of folks will say they can do without, but when it comes to pulling and traction you can't beat the 4wd. That is both in the dry field plowing, wet fields just going from point a to b, and pushing snow. And, finally, there is such a thing as too much tractor, but you will find that there will be times when you want or need a little more. So, if you must choose between two and all things else are equal, go with the bigger tractor.
/ Another newbie - which tractor #12
I don't know. I agree with soundguy with most things, but I strongly disagree when it comes to putting a FEL on a 2wd tractor. Been there, done that. IMHO, an FEL is absolutely completely worthless on a 2wd tractor unless you're putting it on a tractor weighing upwards of 15,000 or more. Few manufacturers put FEL on 2wd tractors anymore with Mahindra apparently putting more FEL's on 2wd tractors than all other brands combined that were built in the last 15 years.
Compared to some guys, I'm new to tractors with only about 25 years or so of heavy use. Still, I would never consider a 2wd tractor, ever, if there was even a remote chance I'd someday need a loader on the tractor. Sure, you'll get some guys saying that they've done this and that with a loader on their 2wd tractor. I can also show you a guy who dug a half acre pond with a slip scraper behind his 8N tractor. It only took him 30 years to do what the right equipment could have done in a week.
/ Another newbie - which tractor #13
soundguy
I don't see 2WD recommended anywhere in this post. Nor in mine.
/ Another newbie - which tractor #14
Look closer; unless they've been removed. You'll see 'em pop up. Heck, everybody can disagree and not get mad. I'm just speaking from hours and hours of frustration with a 2wd tractor with an FEL. The frustration and worthlessness (if that's a word) seems to seep through in my posts on CUT sized 2wd tractors with FELs.
/ Another newbie - which tractor #15
I honestly don't even consider 2wd tractors to be CUTs these days. That may be quirky and I know that old Fords, MF etc etc from the 40's-80's were 2wd but mostly these days we (I) assume that CUTs are 4wd (4w assist really I guess). You have to go out of your way to find a 2wd CUT in the 20-40hp range that has been made in the past 10-15 years.
/ Another newbie - which tractor #16
Dargo.. here's a direct quote from my post:
4wd and sloping land is a good match.. especially if there is a loader involved. 4wd and sloping land is a good match.. especially if there is a loader involved.
I did not advocate getting 2wd.. in fact I sugested 4wd due to the land and loader????????
IMHO, an FEL is absolutely completely worthless on a 2wd tractor unless you're putting it on a tractor weighing upwards of 15,000 or more. .
Tell that to my 4200# * 1955 ford 850 2wd tractor with loader that I routinely use to put out 800-1100# round bales to feed my equines and bovines. :)
* cacl in the rear tires, plus concrete 3pt counterweight.
Hardest working machine on my farm except when it comes to mowing grass.
Still.. I'm a collector of antiques.. not modern tractors.. if I wanted a modern loader tractor it would have 4wd.. and likely somehting other than a plain gear tranny.
since I collect antiques.. 4wd is usually a rare bird in the age range I'm interested in.. though fel's are decently common.... not the greatest on 2wd and limited older hyd systems.. but they sure did lots of work with em back then.. beats a shovel and wheel barrow all to heck!!
soundguy
Thanks everyone for your replies.
What does everyone think about a John Deere 955 with 70a front end loader for my application?
Having my old man look at one in the country tomorrow details:-
1998 JD955 70a FEL 4WD
1514hrs
33hp
Hydrostatic Transmission
Dealer recomended a 4ft to 4ft6in - he said 5ft might be too much for it? I would want at least 4ft6in I think.
Dealer said the mid mount mowers aren't that good for slashing?
$16500 AUD
What do you think - is it a good machine and not too under powered?
/ Another newbie - which tractor #18
Hard to judge the price (would be high in USA with that many hours) but JD tractors are certainly well thought of. I suspect the 955 is one of the JD models actually manufactured by Yanmar which has a fine reputation on its own.
/ Another newbie - which tractor #19
The 955 is the most sought after version of the x5x series here in the states because it has the most hp of the group. They have an excellent reputation and command very good money here. Not sure what the current exchange rate is between $US and $AUS. So, it's hard to comment on the cost. Might look at what they are going for on ironplant or ebay. Might also ask in the JD forum.
While this series is light, I do think it would work ok for you.
/ Another newbie - which tractor #20
4WD for FEL definitely for you as you are going to work in the dirt (motocross track). Pushing into and getting out of heaps of dirt is where the front wheel assist will help. 2WD FEL work is OK when you always have good traction, and you won't.
Older tractors don't (thinking of small agricultural tractors) have clutch-pedal-less forward-reverse shuttle shift, it is another really nice feature. Hydrostatic transmission would also do.
On the JD 955 you found, what type of tires does it have? Because here you have a problem. For working in the dirt with the motocross track you need something that gives good traction - hence agricultural tires. But with gardening turf tires would be preferable to not damage the lawn. I guess the compromise here would be R4 industrial type tires.
2014 MAC FLAMELESS HEATER TRAILER (A67714)
2014 MAC FLAMELESS...
2005 JOHN DEERE 672D MOTOR GRADER (A67714)
2005 JOHN DEERE...
2019 FOREST RIVER WILDWOOD (A67714)
2019 FOREST RIVER...
2025 Kivel 42in Forks and Frame Mini Skid Steer Attachment (A66734)
2025 Kivel 42in...
BOAT MOTOR (A66738)
BOAT MOTOR (A66738)
Unused 2020 Kodiak 4AP Towable Aerator Tractor Attachment (A66734)
Unused 2020 Kodiak...
