Another Permatran question.
   / Another Permatran question. #11
I am getting ready for my 50 hr service and I know there is alot of talk out there about which fluid to use in GC2610 trans. The dealer I purchased from uses kubota UDT in all there Masseys. It seems to work fine. I am looking for input from others out their that used other than Permatran III . I am looking to use Shell Spirax fluid which is a 10w30 like the permatran and according to Shell it exceeds the permatran specs. TSC also has Mystic JT5 which reads to be pretty good. Thanks
With the $$$$$ I have invested in my GC2410, and also the bitter cold and extended long winters we have, I decided to go with the Amsoil for all of my tractor fluids, :thumbsup:. I can promise you my tractor is not turning a shade of orange, :laughing:. My hyd/trans fluid was $9.85 per quart, and 12 quarts were $118.20. Thats $59.10 per oil change as I can now double the time between oil changes from 250 hours to 500 hours, :cool:. I do not think that cost is high considering the quality of fluid provided by Amsoil, :2cents:. KC :D :D :D
You say you can double your change intervals. Is that based on a UOA or on Amsoil recommendations. If it can go twice as long it is a no brainer. Did you notice that the trans operates any better with the Amsoil? How much did that Sims cab cost you?
   / Another Permatran question. #13
Amsoil advertises ATH will last 2 to 5 times longer than other fluids. But, that is with routine oil analysis.
If you double the interval and go 400 hrs., (and that's as far as I am going, because that's a lot of years for me), it's still more expensive that Permatran.
You could probably double the interval with Permatran too, if you did an oil analysis.
Here is what you gain with Amsoil, your cold weather viscosity goes from a pour point of -30F with Permatran, to -51F with Amsoil.
There is also an increase in the high temperature range.
If your not operating in extreme weather, these benefits are not realized. Then, it just costs you more.
I guess what you are saying is that it only benefits in the two temp extremes. My winters average on a nightly low of 15 to20f and day time of 30 to 40f. Summers maybe 90 to 95 tops. I am in southern nys so weather is not to extreme. Maybe I will stick with Permatran. I called a diff dealer than were I purchased from and he gave me a price of $80 for 5 gals.
   / Another Permatran question. #15
I do not know what UOA is, :confused:. Here is a link to the Amsoil I use for the trans/hyd.
AMSOIL - Synthetic Tractor Hydraulic/Transmission Oil (ATH)
Amsoil states the extended oil drain intervals should have an oil analysis company test your oil, I plan on having my oil checked at the next standard MF transmission oil and filter change which is every 250 hours after the 50 hour service is performed, :thumbsup:. I plan on changing the trans/hyd filter at 300 hours. I also plan on changing the trans/hyd fluid also at 300 hours, and saving the Amsoil fluid to reinstall at the 550 hours trans/hyd oil and filter change only after the oil analysis company says it is ok to continue to use, :thumbsup:. I will rotate the Amsoil until it needs to be removed for good. My real concern is the filter with the extended oil changes, so I plan on changing them out every 250 hours, or until someone comes out with an extended filter, :confused2:. Hope I made some sense here. Oh ya, the Simms cab and heater installed was $3995 and is cost effective every winter I do not get sick with pneumonia, :).
B.T.W. if I ever would start having problems with the trans/hyd, I would have it tested sooner. I have noticed the hydraulics work faster after switching fluids when it gets down to minus 30 degrees F. I usually let the tractor warm up for about 45 minutes when it gets that cold. KC :D :D :D
Do you use the same Amsoil in the front axle or do you use something else? Do you think you realize a 20 to 50 degree cooler operating temps that is claimed?
   / Another Permatran question. #17
You should send some time reading past threads, all these things, and probably your next 5 questions have been well covered. Use the search feature.
You can use hydraulic oil in the front axle, but it is better to use gear lube. Any 80-90w EP gear lube will work. Buy synthetic gear lube if you want the low temp performance.
Synthetic EP gear lube is overkill in this application. But so what, it's not that expensive.
   / Another Permatran question. #18
Look, for what it is worth, I used permatran in the front axle because the dealer didn't top off my tranny or axle. So, I had a gallon left over after what I used to fill it to spec. The dealer gave me the permatran. I may switch to gear lube later, maybe, I may use the Amsoil hydro in the front axle. People say the seals leak with the thinner oil, I have not experienced that yet.
I used Amsoil for everything else. I will use Amsoil again due to the fact I am not a fan of mixing different brands after initial oil changes in anything I own. People do, of course, but I have not had any problems "oil related" yet. For the small amount I use (except tranny) quality is peace of mind to me. I work my little machine hard so I will spend the extra money for exceptional lubricants. I think the permatran may be just fine...the Amsoil may be overpriced, go with what gives YOU peace of mind.
Enjoy your investment and stay safe,
Merry Christmas!!:thumbsup:
No need for 5 more questions. My dilemma is solved!! Amsoil it is. Thanks for everything.
   / Another Permatran question. #20
For the front axle, I use Amsoil Synthetic Gear Lube SAE 80W-90 (AGL). My tractor has never operated hot even before my 50 hour service change out to Amsoil, during the summer this year we never hit 90 degrees F at my property. For me its the extreme and long cold winter weather why I have switched to Amsoil. Here is a link to a thread I started about what fluids I decided to use in my GC2410:
http://www.tractorbynet.com/forums/oil-fuel-lubricants/164165-gc2410-50-hr-service-synthetic.html
Good luck with your fluid decisions, :thumbsup:. KC :D :D :D
Deere 310SK (A57148)
flatbed trailer 24ft (A56857)
flatbed trailer...
1996 International Water Truck with a Caterpillar Engine (A56438)
1996 International...
Booster Cables (A59230)
Booster Cables...
CATERPILLAR 30 1/2" PIN ON BUCKET (A52706)
CATERPILLAR 30...
TANK MANIFOLD (A55745)
