Another use for ratchet straps
   / Another use for ratchet straps #11
A fellow farmer taught me that trick about 20 years ago. Saved me big time a couple times
   / Another use for ratchet straps #13
It is much easier and quicker to pop the bead on the rim if you remove the valve stem, add air until the bead locks itself onto the rim, and then re-install the valve stem. Then you can inflate the tire to its proper psi.
That’s useless if the bead is off the rim and won’t seal which was the point of the ratchet strap. The other options are a bead blaster or starting fluid but the ratchet strap is cheap and non violent.
   / Another use for ratchet straps #14
Great idea. If you can, lift the implement off the ground with a jack so the inflated tire will not touch the ground while filling it.
Just so there is no confusion for the inexperienced, only remove the core from the valve stem:
If you don't have the tool, get a core removal cap:
   / Another use for ratchet straps #15
The tire is off the rim in the video. What he does with the starting fluid may be illegal. In the olden times tire repairmen often smoked as they worked, breaking the tire bead with flammable gas inside causes serious injury.
I must admit I was shocked that Everything Attachments actually posted this.
   / Another use for ratchet straps #16
Maybe I wasn,t clear enough in my explanation. You still use the strap in the middle of the tire, and then follow the rest of the instructions. Xfaxman added some great info as well.
Does that make more sense now ?
Two Pairs of 10ft Fork Extensions (A53421)
Two Pairs of 10ft...
UNUSED DIGGIT SCL850 STAND ON SKID STEER (A54756)
UNUSED DIGGIT...
UNUSED IRANCH HYD EXCAVATOR THUMB CLAMP (A54757)
UNUSED IRANCH HYD...
43030 (A51691)
43030 (A51691)
2016 KENWORTH T270 S/A SERVICE TRUCK (A51247)
2016 KENWORTH T270...
2014 Ford F-150 4X4 Ext. Cab Pickup Truck (A55788)
2014 Ford F-150...
