Another vote to replace trailer tires every 6 years. And get TPMS.
   / Another vote to replace trailer tires every 6 years. And get TPMS. #11
Plowhog, I tipped a good recovery guy $5 or 10 for a tractor retrieval. He seemed surprised, said it wasn稚 necessary, but didn稚 argue.
   / Another vote to replace trailer tires every 6 years. And get TPMS. #12
I bought an 8 sensor Bellacorp TPMS from Amazon after having a very similar experience as you had except it was my 32' TT...So far I love it, gives accurate readings and it gives the tire temp which is good enough to tell whether a bearing is overheating. I'll never be without one again.
   / Another vote to replace trailer tires every 6 years. And get TPMS. #13
   / Another vote to replace trailer tires every 6 years. And get TPMS. #14
I air my trailer tires to the max pressure. That way, the tire does not flex as much and stays cooler. My trailers that are parked for any length of time are placed on jack stands so the tires don't sit in the same position with weight on them. Tires need to be used to last longer.
I agree completely. That is the way to do it, even an old tire, especially an old tires. Never under-inflate one because you think it is old and weak. This only causes the rubber to flex more and blow out when a tire with maximum pressure would still be rolling.
   / Another vote to replace trailer tires every 6 years. And get TPMS. #15
^^ What he said.
   / Another vote to replace trailer tires every 6 years. And get TPMS. #16
I think if we could go back in time and actually watch, a very high percentage of trailer blowouts NOT caused by an impact with road debris are caused by the pressure getting low first... You simply don't notice when a trailer tire picks up a nail and starts losing pressure, you only notice when it comes apart...
I lost one on a snowmobile trailer I bought last fall. I never heard it go, and since it has two torsion axles, it didn't drop onto the rim. A nice gentleman let me know the tire was "flat" (Shredded, actually...) as I came into town... I had looked at that tire in the mirror during a turn not 20 minutes before that and it looked fine... My guess is that it was already low, but I just couldn't tell because the rear axle was carrying the weight. Yet another reason I don't care for torsion axles when used in pairs or triples...
IMO, TPMS is a necessity if you want to avoid changing tires on the side of the road, and the damage that goes along with a tire that comes apart... There are several "solar" tpms setups on Amazon for ~$50 that I keep being tempted to try... Several have more than 50 reviews, with little negative feedback, and good results when used on trailers. Sure seems like cheap insurance, and catching a tire that's starting to get low before it comes apart is so much easier than dealing with one after it's shredded.
   / Another vote to replace trailer tires every 6 years. And get TPMS. #17
Almost all (premature) tire failures are the result of under inflation.
Ever try and get the attention of someone to let them know they have a low tire, and they either don't notice or try and ignore you because maybe you appear threatening? And all you can do is say, oh well!
   / Another vote to replace trailer tires every 6 years. And get TPMS. #18
And don"t forget to have your trailer tires balanced.
   / Another vote to replace trailer tires every 6 years. And get TPMS. #19
   / Another vote to replace trailer tires every 6 years. And get TPMS. #20
That's a great idea, I'll have to remember that. Just came back from the tire shop with our trailer that was starting to intermittently vibrate. Turns out two of the tires were separating from the treads. Stored it about a year and things were just too crazy to run it on a regular basis.
Still better to find out now than on the road with a couple thousand pounds of tractor on it.
2021 CATERPILLAR 299D3 XE SKID STEER (A52709)
2021 CATERPILLAR...
Year: 2014 Make: Chevrolet Model: Silverado Vehicle Type: Pickup Truck Mileage: Plate: Body Type: 4 (A55852)
Year: 2014 Make...
(APPROX. 20) 4' X 8' X 3/8" SHEETING (A52706)
(APPROX. 20) 4' X...
2006 Dodge Ram 1500 (A56858)
2006 Dodge Ram...
Pnuematic Transfer Pump on Rolling Cart (A59076)
Pnuematic Transfer...
GEARMATIC WINCH CABLE DRUM (A58214)
GEARMATIC WINCH...
