Antifreeze with sca's or not?
   / Antifreeze with sca's or not? #1
nod
Well i decided to change my antifreeze in my 8560. None of the brands listed in my manual have the sca's in it. I went down to the dealer and they sell the shellzone brand. It does not have the sca's added to it. The owner nor the parts people there has ever heard of sca's. Does the mahindra tractors not need the antifreeze with the sca's?
   / Antifreeze with sca's or not? #2
Wow!! I had to look up SCA - silicone coolant additive. I would have to say - since your OP manual does not call for this additive - as my Kubota manual(2009) also does not - then I would not worry about it. I know from what I could find on the internet - in a brief search - it appears this must be a newer type of coolant additive. Neither of the brands of antifreeze I use - Prestone & Zerex - have sca's in them or at least they aren't listed on the container. Both of the brands I use were purchased within the last year & are designed for HD off road/farm implement use.
I stand corrected - SCA = supplemental coolant additive, I obviously misread the article. Thanks for the correction. BTW, its KC7SW here.
   / Antifreeze with sca's or not? #3
nod,
In my experience with diesels (35+ years OTR) I have learned that SCA's WERE important (at least that is what MOST mechanics thought), but in reality they are not. If you are changing the antifreeze, I would flush out the entire cooling system at least twice. Then replace with a 50/50 mix of Propylene Glycol antifreeze. Use the brand you are comfortable with. Usually this antifreeze will be RED in color. (that is to be able to tell the difference from Ethylene Glycol visually ) The cooling properties and the antifreeze properties are VERY similar to Ethylene, but SCA's are not required. It used to be that SCA's had to be checked and added periodically in diesel engines. Why, I'm not REALLY sure. There used to be a problem with diesels called cavitation in the water jacket around each cylinder that caused pitting on the water jacket side of the cylinder. VERY damaging over time. Switching to Propylene Glycol fixed this problem.
I'm no EXPERT, but I have switched EVERYTHING I have over to Propylene Glycol so I don't have to stock 2 different types of antifreeze. :2cents: Take it for what it is worth, but I have had NO TROUBLE with any of the cooling systems of any of my vehicles. Plus, I found that at Wal-Mart the red stuff is a little cheaper. IMHO this is a win / win deal. :thumbsup: :dance1: :cool2:
Dave
   / Antifreeze with sca's or not? #4
SCA are required for wet liner engines. That is ,the diesel engine has a sleeve for the piston to travel in. This sleeve is subject to cavitation caused by vibrations during the diesel combustion process. Without the SCA, the liner is perforated and bad things happen. If the engine cylinder is bored out of the cast block, NO SCA is required. The mass of the block dampens the vibration and no cavitation occurs.
Deere engines are wet liners, Mahindra ????
   / Antifreeze with sca's or not? #5
hosspuller,
SCA's are no longer REQUIRED in diesel engines. The last 2 trucks I drove OTR had wet liners in the engines and BOTH Cummins and Detroit sent them out WITHOUT SA's. They both had the RED antifreeze in them, which DOES NOT have SCA's present. big truck engine manufacturers have not required SCA treatment since 2009 or 2010, to the best of my knowledge.
That is why I have changed everything I have with a liquid cooling system over to the red stuff. Besides, it is a little cheaper at Wal-Mart.
Dave
That is why I asked about it, I have a 99 ford power stroke with the wet liners and it says to use sca's. Since posting this i found out that mahindra's have wet liners too. It would be nice to be able to swap over to one antifreeze on both of those and not worry about the sca crap anymore.
   / Antifreeze with sca's or not? #7
nod,
That is why I switched everything over. It will not be a problem if you do a thorough flush of the system before putting in the red stuff. when you get around to doing it, let me know how it goes. :dance1: :2cents:
Dave
   / Antifreeze with sca's or not? #8
Tractor Supply sells "Fleet Guard" with the SCA in it.
My tractor manual says use of supplemental corrosion inhibitor along with ethylene glycol will add increased rust prevention and reduce scale formation. I am assuming that means I need sca antifreeze. I'm going to get fleet charge. I'm also assuming that since my tractor has ethylene glycol in it that I won't have to be so careful about flushing all the old out?
   / Antifreeze with sca's or not? #10
hosspuller,
Dave
Pepsiboy. The Cummins engines that were factory filled have liner protection built into the coolant. Even so, the additives have to replenished after time. Cummins sells such. See here : Fleetcool
I just looked at a bottle of automotive extended life coolant. No where does it say diesel liner protection.
I do not believe all "RED antifreeze " will properly protect wet liner diesel engines. I think you're making an unsupported assumption that SCA's are no longer required. Can you provide a link that supports your point?
A dollar or two saved today may mean many $$$ with a perforated liner later.
   / Antifreeze with sca's or not? #11
I use the Fleet coolant from ORilley's...
It is precharged with SCA's and is pink/red in color...
Back when I added SCA's to my antifreeze the fluid was red/pink in color...
I will continue to use the Fleet brand with SCA's in the coolant...
Very convenient for me...
I was not aware of other pink coolants used in cars without SCA's...
Anybody got an opinion on this?
   / Antifreeze with sca's or not? #13
I would flush it good. They tell you that mixing it greatly reduces the life of the sca in coolant. Im around big trucks and equipment all the time. All of them recommend testing the coolant on a regular basis.
   / Antifreeze with sca's or not? #14
Give her a good flush...
That is what I did with my tractor...
Better SCA life with out mixing the coolants...
   / Antifreeze with sca's or not? #15
Wow. can't even winterize your equipment whiteout a tutorial. What is the old green stuff called that I used for 100 years or so.
My 4110 is early 2000. I found the green antifreeze, but had to look hard to find full strength. I hope it is ok to use.
Cheers.....Coffeeman
   / Antifreeze with sca's or not? #16
Last service cycle, I used Chevron Delo ELC in my diesels. It's not all that pricey, and has great performance specs. My local International dealer stocks it. No additional SCA is needed.
Diesel Coolant, Delo Prediluted & Extended Life Antifreeze - Delo - (Canada)
It's been touched on here, but is worth repeating.... Antifreeze/coolant colour doesn't mean a whole lot.... One companies red stuff does not always Equal another companies red stuff......
Unless you plan of getting rid of a piece of equipment within 2 years, IMO it's not worth buying the old green stuff anymore.
Rgds, D.
   / Antifreeze with sca's or not? #17
Put water in it and when it freezes and cracks your block, go buy a new tractor..... Problem solved.
2020 INTERNATIONAL MV607 26 FT BOX TRUCK (A59905)
2020 INTERNATIONAL...
ELECTRIC GOLF CART (A58214)
ELECTRIC GOLF CART...
2018 KOMATSU WA320-8 WHEEL LOADER (A60429)
2018 KOMATSU...
2014 Chevrolet Express 3500 Cargo Van (A55852)
2014 Chevrolet...
2014 Ford F-550 (A55973)
2014 Ford F-550...
500BBL WHEELED FRAC TANK (A58214)
500BBL WHEELED...
