J_J
Super Star Member
- Joined
- Sep 6, 2003
- Messages
- 18,952
- Location
- JACKSONVILLE, FL
- Tractor
- Power-Trac 1445, KUBOTA B-9200HST
If the pump is running continuously, you need a valve that will let the pump flow through the valve when in neutral.
You need an open center valve, so that the cyl will lock when you put the valve in neutral.
Set the relief about 100 psi below the pumps max pressure.
