Westonium
You don't need to be atop any kind of aquifer to put in a horizontal field of tubing to act as the radiator for the geo thermal. PSI/Cinergy may have advocated well-type geo thermal systems in the past, but it is hardly a requirement.
Friends of ours in Plainfield had a vertical geo thermal system, but I doubt they were using the "pump and dump" method. Pump and dump is where they use water once out fo the well, cool or heat the radiator with it, and then dump it into either an empty well (with a lot of capacity), or a pond. Pretty wasteful.
Most geo thermal systems just turn a big section of earth into a giant radiator for the house. I am going to put in the pipes where the dogs will run around so I won't be tempted to plant stuff atop the field, or accidentally dig through it etc.
This is one of the barriers to residential acceptance. Yards are getting smaller, and city folk don't have much call for well-diggers.
Those friends of ours with the vertical geo thermal? They were kidded a bit about it because electricity was quite cheap then. I bet they are the ones laughing now.
