Any Consensus on Trailer Tire Brands???
   / Any Consensus on Trailer Tire Brands???
jsborn said:
I have not seen your trailers and as far as I remember you haven't said weather you have given any consideration to replacing the fenders to allow for bigger tires and wheels? Like I said I don't know this may not be an option but I would sure look into it. You may be able to just have the fenders raised up some and make bigger tires work for you? By the way those prices would bankrupt me too but thanks for letting us know what we were talking about.
The main issue is the spacing between the axles... 33 inches. The second issue is the very limited space between the tires and the trailer frame. Clearance under the fenders is the least of my worries as things stand right now.
Trust me, $249.95 a tire is excellent compared with what I was quoted earlier yesterday. Heck, that's only two grand plus wheels, valves, mounting and sales tax. Piece of cake! :D
Dougster
dullpain said:
Dougster - You did not offend me. I just took you at your word. Near death experience, fix at whatever the cost, etc... I understand now you don't have the wheels rated for these tires. Yes that would be added expense. Just want you to know the Goodyears have performed flawlessly for me , but I had the special valve stems , and heavy duty wheels already. They were the heaviest load rated tires I could find , and thats what I wanted. Hope you find what you need , want and can avoid life threatening situations in the future.
Thanks DP... and I didn't know at the time I replied to you that these tires were, in fact, small enough in diameter to fit okay. Thanks to MJB for setting me straight. They are apparently incredible tires, but the Load Range G thing is complicated and very expensive when all is said and done. Much more research to go. I'm not going to stop looking until I find one of these monsters and decide for myself if this is my very best solution. Lots of opinions out there about what might protect me best... but extremely few, if any, options that meet my full criteria. :eek:
Dougster
   / Any Consensus on Trailer Tire Brands??? #43
Dougster,
I only use LT tire on trailers not ST. Why? The LT are made better. Some will say there is a special pixie dust used in ST tires for UV protection - blah blah blah. How long do truck tires last before they weather check? That hasn't been a problem on automotive and truck tires since the 60's.
Trailer tires are cheaper than LT tires- yes they are. That's why they BLOW OUT.
Do yourself a favor and get some LT's on the trailers. If you can, get ones that can double with the truck's tires in a pinch. LT215-85x16E may fit the bill. That way you can have 2 spares all the time you tow. One on the trailer and one on the truck.
Also, you don't have to buy NEW do you? Around here there a used tire dealers that sell an 85% tread tire in that range of size for about $40 each + install. I know, I can picture your face all scrunched up just thinking about used tires. But, if they fit, would you put your trucks tires onto the trailer? If you could buy ones that are in that shape for 1/4- 1/3 the price of new ... why wouldn't you?
   / Any Consensus on Trailer Tire Brands??? #44
Let me ask an obvious question: why does no one make a Made In America ST tire? It seems patently ridiculous that they've all given up on trailer tires. Does every trailer owner only want the cheapest price, hang the quality? It seems obvious there is a market for good quality tires, as the comments about tires being such an issue on the RV forums, here, etc, attest to. You'd think a smaller player like Cooper or General tire might want to sew up a big niche and make better than Chinese junk ST tires. I've got a boat trailer and tandem axle utility trailer, so I'm sure I'll be facing replacement issues at some not too far off point.
Anyone in the tire business care to comment?
I know it's a hard pill to swallow, but production of virtually all radial "ST" tires has moved offshore...96% of it to China. The only remaining "Made in USA" tire I found (thanks to MJB's input) was the Goodyear Marathon in size ST235/80R16 Load Range D (Note: NOT Load Range E as desired). Carlisle apparently still has a few "Made in USA" ST tires out there, but nothing I can or would use. There are also some "Made in USA" bias ply ST tires out there, but none that come close to working for me. Even tires that are reported by some trailer-related websites to be American made are not (examples: Uniroyal LT radial tires... several sizes... and the Titan ST Radial). I'm guessing the Goodyear Unisteel G614 RST Load Range G tire is still "Made in USA" (as someone recently reported) but I have not seen one yet to confirm that fact. I've located one... yes, just one! ...and will go to see it on Monday.
Dougster
john_bud said:
Dougster, I only use LT tire on trailers not ST. Why? The LT are made better. Some will say there is a special pixie dust used in ST tires for UV protection - blah blah blah. How long do truck tires last before they weather check? That hasn't been a problem on automotive and truck tires since the 60's. Trailer tires are cheaper than LT tires- yes they are. That's why they BLOW OUT. Do yourself a favor and get some LT's on the trailers. If you can, get ones that can double with the truck's tires in a pinch. LT215-85x16E may fit the bill. That way you can have 2 spares all the time you tow. One on the trailer and one on the truck. Also, you don't have to buy NEW do you? Around here there a used tire dealers that sell an 85% tread tire in that range of size for about $40 each + install. I know, I can picture your face all scrunched up just thinking about used tires. But, if they fit, would you put your trucks tires onto the trailer? If you could buy ones that are in that shape for 1/4- 1/3 the price of new ... why wouldn't you?
This "LT" vs "ST" tire thing... I think I could write a book or three about it by now. Opinions are strong, firm and very loud on both sides of this debate. But in the end, there is no "Made in America" LT tires for me out there in 235/75R16 LRE or 235/80R16 LRE. I would have to go down in rating... or size... or both. One of the most recommended LT tires for trailers (and most expensive) is the Michelin XPS Rib... but it is not available in either size I could use in LRE. Check it out. (Note that I cannot use a true LT235/85R16 or ST235/85R16... the tires treads would practically be rubbing on each other.)
No used tires for me after my incident and the not-so-nice cop's BS citation. I'm going to ride on the highest load capability, best made steel belted radial tires I can find... preferably "Made in USA"... but foreign if necessary to hit that higher load range E capability rating of 3,520 lbs per tire for at least some level of redundancy. :rolleyes:
Dougster
   / Any Consensus on Trailer Tire Brands??? #47
Dougster
Wow! You're going to buy new tires every time you use the trailer? Must be nice to be rich!
jb
john_bud said:
Wow! You're going to buy new tires every time you use the trailer? Must be nice to be rich! ;-)
jb
First off JB, you of all people know full well that I am DIRT poor. :eek: But I can't be blowing out tires in the middle of jobs and having cops handing me costly citations (with insurance surcharges) for same. Economically, this is not what you'd call a good business plan! :D
Yes, I see your point... but believe me when I tell you that I am going to be ULTRA careful about trailer tires from now on... probably changing them out way before their time. The wonderful Taxachusetts state cops have no sense of humor at all and LOVE to give out tickets. I do not want to be in their sights ever again merely due to a random screw and, subsequently, two flat tires. :mad:
Dougster
Well, the latest is that those magnificent, expensive Goodyear Unisteel G614 RST tires are still "Made in USA". The bad news is that two more Goodyear tire dealers (now up to three) claim that this Load Range G tire is serious overkill for a couple of dual axle utility trailers that both weigh ~2,500 lbs empty. No problem at all carrying a full load (10K gross)... but apparently very bad news when moving around those trailers empty. :rolleyes: Price is out of sight too... just a hair over three grand for eight tires, wheels, high pressure valves and mounting. Price doesn't even include balancing. :(
So it's either Chinese-made tires in ST235/80R16 Load Range E or Goodyear Marathons (Made in USA) in ST235/80R16 Load Range D. Those are my two real world choices... neither one perfect. Significantly higher load capacity... OR ..."Made in USA"... but not both. :(
Dougster
   / Any Consensus on Trailer Tire Brands??? #50
Just reading from the side here, but dang, it sure does seem funny how bent you are about American tires, when the failure (if I understand it correctly) came from a screw on the road, which in my opinion did not particularly care where the tire was made.
From my view, if you want to prevent a recurrence of this problem, something like Slime or run flat lube would be of more benefit then where the tire was made.
LOAD OUT AND SHIPPING (A57454)
LOAD OUT AND...
2022 Wacker Neuson LTV6 Towable Light Tower (A56857)
2022 Wacker Neuson...
13042tx (A55973)
13042tx (A55973)
2015 Jeep Cherokee 4X4 SUV (A56859)
2015 Jeep Cherokee...
Preliminary Listing / Full Catalog Coming Soon! (A57148)
Preliminary...
40' CONTAINER (A58376)
