Any info on B3300?
   / Any info on B3300? #1
msengstock
Connecticut
JD X728
I was in the process of getting quotes on a b3200, and one of the dealers said the B3200 was going to be replaced with the b3300 in the sping ... they said the machine was going to be about the same but with a slightly larger engine and icreased efficiency ... anyone have any details on the 3300?
   / Any info on B3300? #2
its not being replaced, its in addition to the B3200. It will be a very similar tractor but with larger tires, to close to gap between the B's and L2800/3400 some.
Thanks for the info. Makes more sense now.
   / Any info on B3300? #4
Anyone have more info.? 3 or 4 cyl. engine? Anything to address the vibration issue the 3200 has had? Will it take an MMM? If so, will it be free-floating/suspended or full weight on wheels?
   / Any info on B3300? #5
its a 4 cyl. The "vibation issue" is one of those things that seems to only really exist on the internet. I've never run into it. I don't think it will take a MMM... the 'SU' tractors are pure utility machines and they probably cut the mid PTO to save cost.
   / Any info on B3300? #6
You didn't say this same thing about the abrupt stop in reverse on the 50 series, did you? As you can see I have a B3200 and it doesn't seem bad to me at the RPM's I run it. Around 2000-2200 but is does increase some with higher RPM's but still not a problem for me. BX's and L were/are smoother and I believe my former B7800 was similiar to my current B3200.
   / Any info on B3300? #7
So because you haven't run into it...... it must not exist.....hmmmm.... thats interesting.....if your ever down in the Florida Panhandle I can show the "vibration issue".
Stu
   / Any info on B3300? #8
Does the engine have greater displacement/torque than the 3200 or is this the same engine ramped to higher RPM in order to rate it @ higher hp?
   / Any info on B3300? #9
Same engine I think. I also think its 32Hp. I did not attend the meeting where the info was given out for these... this is just what I remeber being told. These don't ship for a few months yet.
No. I did not. That was a pretty legit problem... over blown in my mind.. but legit. I did say that about the mystical jerky L3400 3pt. That's probably what your thinking.
2016 Ford Explorer 4x4 SUV (A44572)
2016 Ford Explorer...
2013 International DuraStar 4300 Truck, VIN # 1HTJTSKL8DH329389 (A44391)
2013 International...
1992 Leroi 185 Towable Air Compressor (A44391)
1992 Leroi 185...
2016 Kubota RTV-X900 Utility Cart (A44572)
2016 Kubota...
Adams 5-Ton Ground-Driven Fertilizer Spreader  Reliable & Field-Ready (A46877)
Adams 5-Ton...
2014 Dodge Challenger SXT Coupe (A44572)
2014 Dodge...
