Any issues with mis-matched hose sizes?
   / Any issues with mis-matched hose sizes? #11
At the low flow rates used in ag, laminar to turbulent flow or back is not an issue. Downsizing in a line is not really different than inserting a flow restrictor....metal disc with a calibrated hole in it.....Your tractor hydraulic system has different sizes in the casting and connecting tubing, right angle fittings and this and that....then there are the control valves and all.
Don't worry about it but expect slower responses as you downsize parts of the system as others have indicated. Sometimes it's good, like when you are using a hydraulic operated implement of considerable weight that you don't banging down when you drop it.....this is usually where the flow restrictor is used.
Most tractors already have a variable restrictor whereby you can set your raise/fall rates. Not an expert, just things I picked up over the years.
2022 John Deere 1023E MFWD Compact Utility Tractor with 120R Front Loader (A56438)
2022 John Deere...
2003 John Deere 110 Backhoe (A59213)
2003 John Deere...
Sedan (A59231)
Sedan (A59231)
excavator trenching bucket- one bucket per lot (A56436)
excavator...
(APPROX. 20) 4' X 8' X 3/8" SHEETING (A52706)
(APPROX. 20) 4' X...
17501-FL (A56857)
17501-FL (A56857)
